Best Product To "seal" Access Panel In Hvac Duct? - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 04-19-2012, 06:25 PM   #31
Rewards Points: 1,478
I don't really mind the tstat issue. I have zones for first floor and second floor already. I would just put the heat or air on using the first floor tstat.
Doc, what would you reconfigure? And what would you do to zone it?
mikegp is online now   Reply With Quote
Old 04-19-2012, 06:29 PM   #32
Originally Posted by beenthere View Post
A hinged trap door that measures 1" less then the width of your duct and is 1/2" shorter then the duct that swings up will work. it will block 90% of so of the air from going to the first floor.
Alright! Someone on my page. So back to the original question, haha. What would be a good seal to put around the hinged door? Some type of rubber gasket/1/4 inch roll? Thanks everyone.
Old 04-19-2012, 06:40 PM   #33
An old Tradesmen
Rewards Points: 7,808
1/8" thick foam insulation. its sold by the roll, 2" wide.
Old 04-19-2012, 06:42 PM   #34
I'm Your Huckleberry
Rewards Points: 2,270
You'd need one main trunk line with a motorized damper in the duct running to each zone/stat.
http://www.zonefirst.com/products/DesignManual.pdf
Thanks.
Doc Holliday is offline   Reply With Quote
Drywall access panel question priestj Drywall & Plaster 4 03-13-2012 08:14 AM
Installing a cat flap/pet access door on a standard interior panel door? GordCooper Remodeling 7 03-08-2012 09:02 PM
removing access panel on jetted tub zamboni Plumbing 2 01-30-2012 09:23 PM
Sub Panel GND and mixed 240/120 VAC branch curiousB Electrical 12 01-17-2012 10:49 AM
HVAC duct through a fire rated wall elmaur Building & Construction 2 05-30-2011 12:22 PM
