Which Is Best Lennox Brand? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-03-2012, 10:58 AM   #1
Which is best Lennox brand?
OK, so I think I will go with one of the following "Lennox" models/quotes, noting that I won't be choosing an R22 coil!
Any recommendations on Merit vs Aire-flow vs Concord?
1. 80%, 70K, $3,250, Lennox, MERIT ML180UH070P36A, Coil: CX-34-31 R22
2. 80% ?K, $3,700, Lennox, AIRE-FLO 80AF1D070P12A, Coil: AC24AE1A COUNTERFLOW EVAPORATOR COIL
3. 80%, 70K, $3,100, Lennox, Concord, Coil: R410 ready
stigwort is offline   Reply With Quote
Old 11-03-2012, 11:10 AM   #2
HVAC Tech/Owner
Rewards Points: 604
none of them, only because the lennox distributor in my area are a bunch or primadonnas
Technow is offline   Reply With Quote
Old 11-03-2012, 12:07 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
Why not go with a unit that has a higher effeciency? If your going to spend that money....toss in a few more bucks and save it in the long run.....especially if your in a cold climate.
Also check with your local gas company....good chance they offer rebates for higher effeciency units....in most cases the rebate will be enough to cover the difference.
Old 11-03-2012, 01:42 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 2,296
AireFlo and the Lennox unit are now identical. Not sure who makes it for who but they are the same just a different color. You pay more for the Lennox name. I would be more concerned that the contractor is reputable with a good history and reference than price.
The Following User Says Thank You to yuri For This Useful Post:
Technow (11-03-2012)
Old 11-03-2012, 03:59 PM   #5
What about the 80G1DF070AP12 Concord model? Is that comparable to these 2?
Old 11-03-2012, 05:00 PM   #6
Hvac Pro
yuri's Avatar
we don't have them where I am. Concord is more in the US but I suspect Lennox is making them for all 3 companies and it is the same unit. more cost effective to use the same parts, manufacturing dies etc etc. Probably using some of AireFlo's factories but the standard of construction is Lennox quality.
Old 11-03-2012, 05:16 PM   #7
Rewards Points: 6,652
There is also the Armstrong Air division of Lennox. If you can afford it, go with what you can afford, and what it is worth for the home value. http://www.armstrongair.com/ I have a Armstrong a/c unit and love it. Nice and quiet.
Old 11-03-2012, 05:21 PM   #8
Rewards Points: 582
are you aware that its my understanding as of may 2013 80% furnaces will no longer be sold.......ben sr ...go with higher effy.
Old 11-03-2012, 06:07 PM   #9
Hvac Pro
yuri's Avatar
I looked at the Armstrong site and a product brochure with inside pics and it looks a LOT like the Lennox. Probably Lennox is building one furnace in their plants plus Armstrong/AireFlo/Concord/Ducane's plants as they own all 4 brands and stamping different names on them like ICP does. Good business plan to use all the same parts and keep inventory costs down etc etc. Only specific unit of Armstrong they will keep is the package condo units.
Undecided between Lennox 13SEER / 11EER 13GCSX or Rheem 14SEER / 12EER RRPL Sommalina HVAC 2 10-05-2012 06:51 PM
What brand of furnaces do you work on? R u brand specific? Liberator HVAC 7 01-25-2012 08:17 PM
Lennox ML193 with a Filtrete wiz561 HVAC 26 01-15-2012 04:01 PM
Cordless power tool brands - What's your fave? spaceman spif Tools 61 01-11-2011 03:25 PM
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 06:37 PM
