Best Heatpump On Market? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-24-2010, 12:45 PM   #1
Best heatpump on market?
Does anyone have any thoughts on which are the best heatpumps on the market? Trane, Rudd, Carrier? Are they virtually all the same with the main difference is the installation of the unit?
brokennow is offline   Reply With Quote
Old 08-24-2010, 02:15 PM   #2
Yes, the difference in quality of the installation is much more significant then the difference among brands.
Most units use industry standard components like Emerson compressors, GE motors, Ranco electronics, etc, etc so the differences just aren't that great.
A builders grade unit properly sized and installed can be far superior to a high end unit installed by a "hack".
Choose the best contractor you can find and then go with the brand they recommend for your home. I wouldn't deviate from the brand they recommend because you want the contractor to be familiar with what they install and more important is the clout the contractor will have with the manufacturer/distributer if there are issues that arise.
hennyh is offline   Reply With Quote
Old 08-24-2010, 03:07 PM   #3
Rewards Points: 95
There are fewer differences between heat pump brands then there are between furnace brands.
There are some differences in defrost modes and diagnostics though.
The quality of the installation is critical.
garya505 is offline   Reply With Quote
Old 08-24-2010, 03:36 PM   #4
How do you determine best installer
What criteria should you use for the best installer...Years in business, references, etc???
Old 08-24-2010, 03:54 PM   #5
Rewards Points: 95
I'm grappling with that question now. Personally I favor the smaller "owner/operator" companies - like the family operations that have been in business for years. You, know the guys that eat, sleep and breathe this stuff. I don't like the big companies that have sales guys to convince you that their brand is the best, and then send their installers to do the job. I like the guy who's reputation is at stake on each job he does, and is proud of his workmanship.
For me, I have a specific system in mind that I think is best for my home. I'll be looking for someone who is very familiar with the hardware. However, it was a A LOT of work to spec this system for me (a non-pro), so I don't recommend going that route unless you are somewhat of a control freak like me.
I do recommend that you get familiar with HVAC basics, so when they start making proposals you can evauluate them with some confidence. The more you know, the better.
Old 08-24-2010, 08:42 PM   #6
Word of mouth from multiple sources is best. Building inspectors, HVAC supply houses, friends, neighbors, other trades professional, etc.
Make sure the contractor does a Manual J load calc. If they're too lazy to calculate system sizing then send them packing because they're not looking out for your best interests.
A long term reputation in the community is also good. You can also check BBB for % resolved complaints. Also check the state contractors board.
Old 08-24-2010, 10:01 PM   #7
Rewards Points: 95
I found word of mouth from friends and neighbors to be the least reliable method. Most of them don't know if their systems are really any good or not (except maybe they know when they have a botched-up install).
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 03:59 AM
Can you run a heatpump with W8835 Envirazone with IAQ TH9421 zootjeff HVAC 4 05-10-2010 06:19 AM
Frigidaire Heatpump/ Honeywell 3611 digital thermostat shanbrt HVAC 3 06-08-2009 07:27 PM
HeatPump concerns walt1122 HVAC 11 03-02-2009 06:56 PM
Market price on roofing in Houston, TX Davidpowers99 Roofing/Siding 4 10-29-2008 08:06 PM
