Best Fittings From The Boiler? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-14-2009, 07:14 PM   #1
Best fittings from the boiler?
I was looking for input as to the best fittings from the boiler to the taco pumps in a radiant heat system.(T's reducers, stubs, etc.) Cast iron would be my first choice. There is also black, galvanized, and bronze. I don't want copper in this section of the piping if at all possible. I have a system where the zones are controlled by individual thermastatically controlled pumps. Thanks in advance.
jr67z is offline   Reply With Quote
Old 10-22-2009, 02:28 PM   #2
waiting for answer on this one, just wanted to bring to top!!
geobckmstr is offline   Reply With Quote
Old 10-22-2009, 03:09 PM   #3
if the boiler is copper tubed...i would use a dielectric union and go to black pipe.
I would personally put the pump (if the boiler doesn't have a pump) if designed properly at the supply side of the boiler with a pressure and temperature gauge on the discharge side of the boiler.
Viper16 is offline   Reply With Quote
Old 10-22-2009, 03:25 PM   #4
An old Tradesmen
Rewards Points: 7,780
Black pipe, if your radiant loops are using Hpex. or some other oxygen barrier material.
If not, then copper, brass or some other non ferrus material.
Old 10-22-2009, 04:51 PM   #5
GC/Master Plumber/Mech
Rewards Points: 560
Pumps go on the return
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 10-22-2009, 05:43 PM   #6
thanks everyone...I do have oxy barrier tubing so I think that black pipe would be the best choice for me
Old 10-22-2009, 07:06 PM   #7
An old Tradesmen
Why?
Circs on the supply can have several advantages over having them on the return.
Old 10-23-2009, 11:46 AM   #8
Don't forget the dielectric union if the boiler is copper...you will cause some nasty corrosion.
Old 10-23-2009, 01:33 PM   #9
will do...thanks
Boiler questions mudpaws HVAC 4 06-11-2009 08:22 AM
Need Help I Have a BOILER PROBLEM mikerouse1989 Plumbing 7 02-01-2009 05:07 PM
Tankless coil in oil-fired boiler lebeld Plumbing 4 01-18-2009 08:48 AM
Burnham V7 series oild-fired boiler is turning itself off Pickngrin HVAC 6 01-12-2009 08:26 PM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 04:21 PM
