Best Approach - HVAC - DIY Chatroom Home Improvement Forum
Old 06-10-2010, 10:04 AM   #1
Rewards Points: 292
Best approach
My attics have R30 batt insulation and full length soffit vents, front and back, which are open, and Cobra ridge vents (previously perforated metal). Despite this, I have never been able to demonstrate any airflow into the soffits, or out of the ridge, and attic temps do rise. The shingles are black.
The roof seems to radiate heat into the 2nd floor and directing more airflow (via dampers) doesn't seem to help.
Which, if any of the following, would be helpful?
a) remove batts; foam the joists, then return batts
b) foam the inside of the roof
c) radiant barrier inside of the roof
d) any combo of the above
I had sized the a/c at 3.5 tons (down from 4), but the contractor talked me into a 2 stage 4 ton (which doesn't never runs in 2nd). In retrospect, the 3.5 unit would have given me about 300 more CFMs.
When the system was installed, the return ducting in the basement was upgraded, and 2 lower return grills were added (downstairs) and the upstairs grill was enlarged. This has improved comfort downstairs, but has only added minimal gains to the upstairs.
I had looked into zoning, but have ruled that out.
What say you?
Edit: 1:00 PM, went up in the attic to do some antenna work and it was hot as hell (not quite as bad as on a 90 degree day. OD temp low 70s. It's been cold these mornings (50s overnight), but it's still hot from the last hotspell. With windows open and the attic hatch cracked, there was a little movement of tissue when the wind blew.
veesubotee is offline   Reply With Quote
Old 06-10-2010, 01:00 PM   #2
An old Tradesmen
Rewards Points: 8,194
Knowing the outdoor and attic temp, would have told us more, then just telling us it was real hot.
Radiant barrier would probably be you best bet.
Old 06-10-2010, 03:08 PM   #3
Rewards Points: 292
Sorry. I just took the temperature. It was 118, OD was 83.
Old 06-10-2010, 03:15 PM   #4
An old Tradesmen
30 to 35 hotter then outdoor temp is not unusual.
Once the sun is shinning on those shingles. The temp goes up quick.
RB, will keep a lot of that heat from getting in.
Building knee wall in basement, best approach? RyanD Building & Construction 6 07-04-2009 01:07 PM
Best approach on removing trees for a driveway through vacant land? moneymgmt General DIY Discussions 4 04-23-2008 02:42 PM
Roof used as a deck - what is a good approach rogersor Roofing/Siding 3 09-19-2007 01:05 PM
How to approach toilet clogging KUIPORNG Plumbing 11 01-31-2007 08:58 AM
Approach to demo bathroom ceramic tile floor for remodel corky Flooring 3 01-29-2007 09:59 AM
