Before During And After, A Pictorial - HVAC - DIY Chatroom Home Improvement Forum
Old 07-22-2011, 06:25 PM   #1
I'm Your Huckleberry
Rewards Points: 2,270
Before During and After, A Pictorial
Of course this took out the condenser fan motor so that got replaced and it was not cheap. Nothing but OEM for this bad boy. 1/15th 800 rpm, 208/230. 5 MFd.
Doc Holliday is offline   Reply With Quote
Old 07-22-2011, 07:13 PM   #2
JJboy's Avatar
Good Job Doc.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-22-2011, 09:40 PM   #3
Thanks, man. Just another day in the life of an hvac tech.
I was testing my phone's camera, glad it worked. I have a few more pics I 'll get around to posting, blown caps and whatnot/ Thought it'd be fun to have pics of the good, the bad and the ugly. And the repaired.
Old 07-22-2011, 10:04 PM   #4
Some more of the condenser, before.
Old 07-22-2011, 10:09 PM   #5
Blown 80/5 run cap. You can see the oil and the rounded top so no need to even test it.
I only had an 80/7.5 dual so to keep the fan spinning at it's right speed I jumped to a single 5 mfd.
Best part of my day, restocking at the supply house!
Old 07-22-2011, 10:30 PM   #6
JJboy's Avatar
I know you will end up going to make a Youtube movie. Here is a great free program. http://www.formatoz.com/
Old 07-23-2011, 06:47 PM   #7
Not sure I'm going out to try and be the next Dr. Zorloff youtube hvac tech, but I might use that for something else, thanks.
So I go back to my sister's place to remove the suction drier (no pressure drop whatsover, one week later but I did remove the shraeders and charge and release ntirogen from both lines, twice at time of compressor install so no surprise there wasn't any restriction)
and I find the system low on refrigerant, accumulator leaking.
Old 07-23-2011, 07:02 PM   #8
Another twenty five minute drive to Carrier and twenty five back and
plus a cleaning
while I nitro tested it at 250 psia
dopped the nitro charge, vacuumed for 45 minutes and I left it at this
