My house is about 1300 square feet, I have a 2 ton heat pump and 15kw electric heat. I have no problem keeping my house warm except my bedroom. If I have the temp set at 72, my bedroom is 69. At first I thought it was a window so I put plastic over it. Still the same. When I am running my heat pump I have about 90 degree air coming off the coil and it runs at 89 at the register in the room. Is there a way to calculate the size of air duct you need in a room? I'm thinking the air duct and supply line are possibly not large enough for the room...
No there is not a cold air return in the room. I have somewhat of an open floor plan. I have a single cold air return in the center of the house, though there is a wall between it and the bedroom.
Many new homes use the space at the bottom of the door as the cold air return. if leaving the door open solves the problem check to see if you have at least 1 1/4 inch of space between the bottom of the door an the floor or carpet.
One solution to this problem may be that you add a "scoop" to the lateral which runs from the main supply line to the bedroom. This is just a piece of sheet metal shaped like a, well, a "scoop". I had the same problem with one bedroom of this house I am currently sitting in, the main bedroom at that. I thought about having the wife sleep elsewhere to see if the room would warm up, but that didn't work either. A friend in the business told me about the scoop, how to build one, and I installed it myself. It just directs a little more air into the lateral going to whichever room. Of course this robs a little air from the rest of the system, but in my case I never noticed it. I'm cooling 2060 sq. ft. with a 3.5 X-duty AC/heat pump and all is well now. Maybe this will help, David
That works ok. If the take off isn't one of the last ones on the trunk.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
