-   -   beckett oil furnace (http://www.diychatroom.com/f17/beckett-oil-furnace-164638/)
lilred1111@yaho 11-25-2012 12:18 PM
beckett oil furnace
No fuel coming from bleeder screw
oh'mike 11-25-2012 12:54 PM
Moved to heating
beenthere 11-25-2012 02:06 PM
Is there oil in the tank? Is the oil filter plugged?
HVACTECH96 11-25-2012 04:55 PM
check coupler from mtr to pump
COLDIRON 11-26-2012 06:40 AM
Change the oil filter, open bleed valve put small clear hose over bleeder and put it in a container, start system watch bleeder for clean stream of oil no air, you might have to push reset a couple times to get oil to flow, when oil flows with no air shut down and close bleed valve and fire up boiler. NOTE: Only push reset button a couple times when bleeding, never push reset more than once or twice if having burner trouble.
av-geek 11-26-2012 01:49 PM
oil will not come out bleeder unless burner (oil pump) is running. Make sure filter is not clogged, and valve on filter is not turned off
