Old 01-08-2011, 07:26 PM   #1
beckett oil burner pump problem
the burner goes on but no fuel in the chamber. i disconnected the fuel line on the back side of the pump turned on the burner and no fuel comes out.there is fuel out of the bleeder valve.is the pump bad?
slacov is offline   Reply With Quote
Old 01-08-2011, 07:36 PM   #2
My other Beckett starts fine,flame is good,but only runs for about 30 secs then the primary trips off. Any ideas?
Old 01-08-2011, 07:44 PM   #3
Master General ReEngineer
Bondo's Avatar
Ayuh,... My 1st guess is the flame sensor is dirty, or dying...
The Following User Says Thank You to Bondo For This Useful Post:
slacov (01-16-2011)
Old 01-08-2011, 07:46 PM   #4
Bondo's Avatar
Ayuh,... You're saying you get fuel out of the bleed screw, but not at the fuel line to the burner,..??
Ya, that sounds like a pump problem to me...
slacov (01-16-2011)
Old 01-09-2011, 12:04 AM   #5
I disconnected the cad cell and ran the burner. It is cutting off with or without the cad.
Old 01-09-2011, 04:50 AM   #6
An old Tradesmen
Was there an actual flame when it ran and tripped the safety. if not. Stop pushing the reset.
Old 01-09-2011, 05:06 AM   #7
An old Tradesmen
Merged your threads. Please don't make multiple threads about the same problem, thank you.
Old 01-09-2011, 07:04 AM   #8
Bondo's Avatar
Ayuh,... It needs a Clean, Working cad cell....
Of course it shut down without it wired in...
slacov (01-16-2011)
Old 01-09-2011, 08:03 AM   #9
Put the cad cell back it's a fuel problem. Now your not getting fuel to the burner, relax and think about it, your getting fuel out of the bleeder on the pump, is it a good solid stream? Or does it have air mixed with it?
You might have to attach a rubber hose to the bleeder and run it into a can to make sure it's a good solid stream before closing the bleeder and restarting. Listen to Been DO NOT KEEP PUSHING THE RED RESET IF YOUR NOT TO SURE WHAT'S HAPPENING. IF YOU DO SOMEONE UPSTAIRS CAN EXPLAIN IT TO YOU WHEN YOU GET THERE.
COLDIRON is offline   Reply With Quote
Old 01-10-2011, 02:50 PM   #10
I was talking about 2 separate burners.1 of them is in the stable(the cad cell question) and the other burner is in the house(the question about the pump) I'll get a new cad for the stable burner. the house burner has a problem with the pump. There is a strong flow at the bleeder valve but nothing out of the backside of the pump.I disconnected the short fuel line that goes from the backside of the pump to the tube that has the nozzle on it. There is no oil coming out of the elbow attached to the back of the pump when the burner is turned on. Hope this clears this post up. any help with the pump question would be appreciated.
Old 01-12-2011, 03:16 PM   #11
Can anyone tell me how to remove the pump and how is it connected to the motor?
Old 01-12-2011, 04:27 PM   #12
Bondo's Avatar
Ayuh,... Disconnect the fuel lines,...
There should be 2 or more bolts holding the pump to the housing,..
The pump is joined to the motor by a Love-joy coupler...
slacov (01-16-2011)
Old 01-12-2011, 05:14 PM   #13
Not sure about this maybe someone else will chime in. Quite a few oil pumps have a cylindrical screen in them, you have to take the end of the pump apart usually 4 screws and remove the end plate inside there you will see a screen MAYBE , if you do pull it out and clean it.try not to muff up the gasket on it or it will be double trouble. If I am wrong you'll see me getting ripped here just keep looking before you do anything drastic.
If you follow the procedure above then re-bleed the pump in a bucket before firing boiler.
Old 01-12-2011, 09:28 PM   #14
An old Tradesmen
If its not a Webster pump, it will have a screen.
furnace burner problem brent h HVAC 2 01-11-2010 08:50 PM
Broken Burner Fix mikelbeck HVAC 2 01-16-2009 10:05 PM
Oil burner problem bobm202 HVAC 1 01-14-2009 02:30 PM
Heat pump problem trprider HVAC 1 07-22-2005 12:15 AM
Sewage pump problem Unregistered General Discussion 1 10-03-2004 10:52 PM
