Old 11-27-2012, 06:30 AM   #1
Beckett Oil Burner
I have a beckett oil burner. I have this int. problem. At times the furnace does not light off. I have troubleshoot the problem down to the cleancut pump. The question I have is I don't know if the problem is the pump or the solinoid. If I tap on the pump the furnace will run.
mrcheddar is offline   Reply With Quote
Old 11-27-2012, 11:08 AM   #2
Beckett Oil Burner
check wire connections to solenoid..may be loose and make contact when tapped..could also be sticking solenoid. if so replace it.
techpappy is offline   Reply With Quote
The Following User Says Thank You to techpappy For This Useful Post:
mrcheddar (12-07-2012)
beckett oil burner quarry112 HVAC 0 10-29-2011 07:48 PM
beckett burner lanebriggs HVAC 0 06-27-2011 11:34 AM
Air leak on Beckett Burner Phr00t HVAC 2 05-22-2011 11:35 AM
Beckett Oil burner ricbrk HVAC 1 08-25-2010 08:26 PM
Which beckett burner do I need. jmhai HVAC 6 01-11-2010 09:42 PM
