-   -   Beckett Oil Burner (http://www.diychatroom.com/f17/beckett-oil-burner-164846/)
mrcheddar 11-27-2012 05:30 AM
Beckett Oil Burner
I have a beckett oil burner. I have this int. problem. At times the furnace does not light off. I have troubleshoot the problem down to the cleancut pump. The question I have is I don't know if the problem is the pump or the solinoid. If I tap on the pump the furnace will run.
techpappy 11-27-2012 10:08 AM
check wire connections to solenoid..may be loose and make contact when tapped..could also be sticking solenoid. if so replace it.
