Old 04-01-2008, 09:29 AM   #1
beckett honeywell afg
hi i ran out of oil over the weekend had the tank filled monday. it will not start no matter what i try, tried the reset button nothing happens. i turned it off loosened the bleed line and then turned it back on in an attempt to bleed the system but no fuel comes out? any other ideas?
nicholas2k8 is offline   Reply With Quote
Old 04-02-2008, 05:49 AM   #2
Mainah's Avatar
you need to run it while the bleeder is open, into a soda can or something-
when you get a good flo of oil tihghten it up- you may have to reset a couple time during this process.
if you ran that pump dry too many times you probably burned the pump out-
Mainah is offline   Reply With Quote
Old 04-02-2008, 02:48 PM   #3
it was a first time and a last. the problem was that the reset button was locked out, you had to hold it down for like a minute then do it again
Honeywell Thermostat Wiring Differences DavidHwang HVAC 16 01-28-2012 03:11 PM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 05:43 AM
Honeywell VisionPro 8000 Temperature Variation hottoddy HVAC 3 01-01-2008 02:33 PM
Changing from one Honeywell to another... LeroyFrick HVAC 1 11-03-2007 12:33 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
