-   -   beckett honeywell afg (http://www.diychatroom.com/f17/beckett-honeywell-afg-19357/)
nicholas2k8 04-01-2008 08:29 AM
hi i ran out of oil over the weekend had the tank filled monday. it will not start no matter what i try, tried the reset button nothing happens. i turned it off loosened the bleed line and then turned it back on in an attempt to bleed the system but no fuel comes out? any other ideas?
Mainah 04-02-2008 04:49 AM
you need to run it while the bleeder is open, into a soda can or something-
when you get a good flo of oil tihghten it up- you may have to reset a couple time during this process.
if you ran that pump dry too many times you probably burned the pump out-
nicholas2k8 04-02-2008 01:48 PM
it was a first time and a last. the problem was that the reset button was locked out, you had to hold it down for like a minute then do it again
