Beckett HeatManager - HVAC - DIY Chatroom Home Improvement Forum
Old 08-17-2010, 10:31 AM   #1
Beckett HeatManager
Anyone ever used a Beckett HeatManager with a Weil-McClain WGO boiler? Thoughts?
BOUTYM is offline   Reply With Quote
Old 08-17-2010, 05:24 PM   #2
An old Tradesmen
Rewards Points: 7,826
Get an outdoor reset control. The heat manager isn't nearly as good as an outdoor reset.
Old 08-17-2010, 05:45 PM   #3
Rewards Points: 1,542
In a traditional forced hot water system, when the thermostat calls for heat then the burner and the circulator come on. When the thermostat stops calling, the burner and circulator go off.
With the Beckett Heatmanager, if the boiler is already quite warm and the thermostat calls for heat, just the circulator and not the burner comes on. The burner cycles on and off as needed to keep the boiler water warm enough.
Many modern boilers already have the burner cycling on and off while the circulator runs continuously (until the thermostat stops calling) so the Beckett unit does not add anything new.
A completely different economizer has an outside sensor that shuts off the furnace or circulator if the outdoor temperature goes above a certain level. This is a do it yourself-able project.
Old 08-17-2010, 07:07 PM   #4
An old Tradesmen
Outdoor reset works much better then the heat manager.
The heat manager doesn't really do anything when the outdoor temps are 20 or less()Beckett admits it). But an outdoor reset still saves money on the heating bill.
Beckett fuel supply line ThisIsMe HVAC 2 01-31-2010 10:17 AM
Original problem to beckett burner question.. jmhai HVAC 17 01-14-2010 04:25 PM
Which beckett burner do I need. jmhai HVAC 6 01-11-2010 08:42 PM
Beckett RWB Replacement on Weil-Mclain 68 series - AFG, NX??? DPDISXR4Ti HVAC 5 02-22-2009 04:17 PM
beckett honeywell afg nicholas2k8 HVAC 2 04-02-2008 01:48 PM
