Baxi Luna 3 - Won't Power Up - HVAC - DIY Chatroom Home Improvement Forum
Old 06-17-2012, 09:04 PM   #1
Baxi Luna 3 - won't power up
Hi, I have a Baxi Luna 3 and it will not power up. The LED reading is completely blank, as if no power is on the unit at all. I checked the outlet where it plugs in, it is fine, the light I plugged in worked ok. A few things to consider:
- the propane service was recently disconnected from the house and reconnected.
- I kept getting "E03" error code, so a sensor (switch?) was replaced to fix it.
Any ideas why this thing won't even come to life? Is there a reset switch?
thanks.
phish-jc is offline   Reply With Quote
Old 06-17-2012, 09:43 PM   #2
Rewards Points: 494
Someone switched the emergency shutoff switch to OFF by mistake? The one that might have a red cover?
Any reset switch?
diyorpay is offline   Reply With Quote
Baxi Luna 24fi Flow Rate TXT HVAC 1 03-20-2012 05:06 PM
Power strip hack salex Electrical 3 01-31-2012 06:10 AM
Recurring Power Oddities - Regular Schedule DamienChaos Electrical 16 10-21-2009 07:45 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
