Baxi Luna 24fi Flow Rate - HVAC - DIY Chatroom Home Improvement Forum
Old 02-09-2012, 01:47 AM   #1
TXT
Hi,
I have a Baxi Luna 24fi that's probably 12 years old. Was serviced about 4 months ago and was fine.
The heat works fine, but I'm having problems with the DHW (no hot water). I noticed if I turn on the washer set on hot, the unit ignites and works. If I then turn in the bathroom tap and shut off the washer, the unit continues to heat the water. I also noticed if I turn on the tap and shower, the unit will heat the water. However, turning only one tap will not activate the unit. From reading around, it sounds like a flow issue. Any ideas?
Your help is much appreciated.
Thanks,
TXT
TXT is offline   Reply With Quote
Old 03-20-2012, 06:06 PM   #2
TXT
The problem was the diaphragm. It was pretty much jello. Replaced the entire casting and works fine.
Tags
baxi , dhw , flow , luna , tankless water heater
flow, rate, pipe diameter w/sump pump D270 Plumbing 2 12-09-2011 11:53 AM
Well Water Flow Rate flynnjpf Plumbing 2 12-01-2011 07:49 AM
I thought I understood plumbing, private well flow rate question ChrisDIY Plumbing 22 07-25-2011 11:14 AM
increasing kitchen flow rate? redline9k Plumbing 2 12-07-2010 06:39 PM
Flow rate at reducer SIDINC Plumbing 2 09-17-2010 10:05 AM
