Old 11-02-2007, 04:34 AM   #1
Baxi 105e problem
Hello Gas folk,
I have a problem with the above mentioned boiler in that my DHW is functioning normally but my CH is not.
None of the usual fault neons are flashing, pressure is normal and I've checked that power is getting through the selector switch to the PCB.
That is the limit of my knowledge, I'm a builder you see. The boiler is 6 years old and non condensing.
If anyone can shed any light on this problem I would greatly appreciate it.
Many thanks.
geordiebuilder is offline   Reply With Quote
Old 11-05-2007, 08:16 AM   #2
Baxi 105e problem
I am in the US and we really don't use this type of boiler. However I did find a installation/owners manual online. http://85.189.44.185/Baxi/. On Page 38 there is a diagnostic flow chart. Of course it shows flashing neon lights as you said you have none. I would try running down threw the sequence in the manual to see if anything shows up?
Also do you have any external controls? (thermostat that may not be calling for heat).
It is possible your control board is malfunctioning do you see or smell any damage to the board burn components or pcb?
Note: The web site for partarene masked the actual page on there site for the manual just go threw the menus to find your unit.
Mgmopar
MgMopar is offline   Reply With Quote
