Old 12-02-2011, 02:07 PM   #1
Bathrooms...
Hello,
Currently I have 2 bathrooms upstairs that have HVAC but neither have fans.
An HVAC guy told me A/C isn't really needed in the bathroom and he suggested
I remove the HVAC vents and add electric heaters and add ventilation fans.
He also said it was ok to hook the ventilation fan to my maxi vent in the roof, I'm not sure if this is acceptable.
Any suggestions?
Thanks!
adamavis is offline   Reply With Quote
Old 12-02-2011, 02:14 PM   #2
Bathrooms...
He needs to stick with working on A/C's.
Never heard of any house in a warm climet not having A/C in the bathroom and see no reason not to.
Every bathroom needs an exhost fan, there needs to be two lines not one if you have two bathrooms and run them through a soffit vent (Lowes and Home Depot sell one just for this) or out the wall.
Old 12-02-2011, 02:27 PM   #3
Military Mom of 4
Snav's Avatar
Bathrooms...
What Joe said: don't over complicate things. Leave the HVAC vent alone. Add in a vent through the ceiling and pipe it out through soffit or facing.
Without adequate ventilation out of the bathroom humidity will be more likely to create mold and other issue.
Neither of my bathrooms were ventilated when I bought the house - they are, now . . . there is a definite benefit to being able to repel steam and odors out quickly.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 12-02-2011, 02:33 PM   #4
Bathrooms...
Never heard of any house in a warm climet not having A/C in the bathroom ..
Might be worth a mention that I live in Montreal, Canada. Highs in summer are around 85-90F. that's from late june to august.
1 bathroom is an ensuite to the master, we're trying to raise the dropped ceiling in the kitchen so it's a pain to put it back in.
the other bathroom is possible to put it back, but it would no longer be under the window, is that ok?
Ventilation fans: I heard before that 2 bathrooms need 2 seperate exits, they can't be T'd into 1 connection. Thanks for validating.
Thanks again!
Old 12-02-2011, 02:40 PM   #5
Bathrooms...
I came home yesterday from work and the wall had beads of moisture on it. I had showered 10 hrs prior. Kinda scary.
Old 12-02-2011, 03:07 PM   #6
Average Joe/ex-Navy IC3
gregzoll's Avatar
Bathrooms...
That means that there is not only not enough air movement, but the attic space above it is not properly insulated or vented. Get a bath fan in there, and if you wold like, use a timer that has a humidity sensor. The catch-22 on those, is if the house moisture is high, the sensor will keep drawing air and not shut off.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 12-02-2011, 05:05 PM   #7
Military Mom of 4
Snav's Avatar
Bathrooms...
My bathroom was 'remodeled' (rather poorly) before we bought it - 4 years later when I was finally ready to get to the master bath I pulled off their trim that they put in the shower and found a massive thick mat of mold, moss and who knows what else behind the wallboard.
I know that wasn't all just because of a lack of ventilation - but it most certainly didn't help.
Old 12-02-2011, 06:09 PM   #8
raylo32's Avatar
Bathrooms...
Here is how the builder did it in my house. The 2 upstairs bathroom vents have ducts that terminate just below a through-roof domed vent fitting that looks like a little UFO on the roof. The ducts terminate just below the underside of the dome.
raylo32 is online now   Reply With Quote
Old 12-02-2011, 07:13 PM   #9
gregzoll's Avatar
Bathrooms...
Raylo, that is not the correct way to do it. The need to terminate in a box, with a single duct attached to the proper vent, that has a damper, so that cold air does not re-enter the space you are trying to exhaust.
Old 12-02-2011, 07:20 PM   #10
raylo32's Avatar
Bathrooms...
Hey, I didn't build the place I just live here. ;-) I always wondered about this setup. Dampers... I am not sure but there may be some closer to the source. I haven't ever felt any cold air infiltration from these vents but something I will have to check out. All the townhouses in my development have the same little dome fitting on the roof but not sure if they all terminate the ducts inside like they did with mine. BTW, the vents for the first level bathrooms have the typical side exits with flapper dampers.
Thanks for the observation, Greg.
Old 12-02-2011, 07:29 PM   #11
gregzoll's Avatar
Bathrooms...
Mine is just flex pipe to the roof vent. Reason being, is due to at the time my wife wanted it in, and we did not know if we were making the upper story into living space. I just left it, but put in a inline damper, which works. Mine is up inside the roof vent, so that it exhausts outside and does not gather into the attic.
It has been that way for eight years, and no signs of problems, due to how well the attic is ventilated.
Old 12-02-2011, 07:35 PM   #12
raylo32's Avatar
Bathrooms...
I also have a ridge vent right near this so the attic is definitely well ventilated. I wonder if there might be dampers right on the fan boxes for these sorts of installations?
Old 12-02-2011, 08:23 PM   #13
gregzoll's Avatar
Bathrooms...
Some have them, but after a while, with the dust they pull, and the moisture, it is like dryer vents. The gunk becomes a mess that causes the dampers to not close. I take mine apart about once a year and clean up the fins and put it back together. It is just plastic, but like I said, it has been temp. This coming spring, I need to get up there and replace with regular ductwork, and wire the roof vent fan, before it gets hot.
Old 12-05-2011, 04:31 PM   #14
Bathrooms...
So do I understand this correctly, I can add a fan in my bathroom and connect it to my roof vent (Maxi vent) with a damper?
Old 12-05-2011, 04:40 PM   #15
Bathrooms...
Nevermind, I found a good image that explained it.
Wiring inline bath fan for multiple bathrooms secutanudu Electrical 27 08-24-2012 03:38 PM
Browse New Generation Bathrooms Design & styles bathroomsuk Plumbing 0 09-20-2010 02:38 PM
Can I T my new dryer's exhaust into my bathrooms exhaust? Felipon Appliances 2 01-30-2008 07:53 PM
supply runs required in all bathrooms? bjherron HVAC 2 11-23-2007 08:56 AM
Ugly tile bathrooms & fixtures - help! inarut Interior Decorating 4 10-29-2007 03:53 PM
