Bathroom Window Vs Exhaust Fan In Basement - HVAC - DIY Chatroom Home Improvement Forum
Old 04-10-2013, 12:53 AM   #1
Rewards Points: 31
Question
Bathroom Window vs Exhaust Fan in Basement
I live in Parker CO and about to start finishing my basement. I will be putting a bathroom down there with a toilet, sink, and custom shower. Our code (2013 IRC) states that i need either an exhaust fan or a window for venting.
My question is which is more cost effective?
I have 3 other bathrooms that have the window and no fan. Would it be harder to install a vent since there isn't one to tie into?
If the window is a better way to go, what are the requirements for the window/window well on the exterior wall? (if any)
Thanks in advance!
ccleme11 is offline   Reply With Quote
Old 04-10-2013, 04:41 AM   #2
DIY staff
Rewards Points: 7,174
Install a vent----drill a hole to the outside of the house----
Old 04-10-2013, 09:01 AM   #3
Rewards Points: 31
Is there a specific type of material/piping that i have to use?
How do i determine what size fan i need?
Old 04-10-2013, 09:26 AM   #4
Bill Kearney
Rewards Points: 1,174
A fan with a timer that'll let it run for a while after your done is a good idea. That way moisture doesn't get left down in a basement bath, contributing to mold/mildew issues. Most fan vendor websites have some sort of calculation you can do to determine the recommended CFM size. Don't forget noise. I hate fan noise and went with some in-line duct fans from Fantech. They're a bit more expensive but the peace and quiet is worth it. Most fans call for a 4" duct. Just make sure wherever you're venting it out is appropriate. As in, not close to a gas line, exhaust for a furnace or water heater, or in a place where the moist air would cause problems (like tight under something else that would have a problem with moisture).
wkearney99 is offline   Reply With Quote
Old 04-10-2013, 09:49 AM   #5
Rewards Points: 31
Im thinking the best place to vent would be out the side of the house to the left of the window. Is there a code for how many feet the exhaust fan vent needs to be away from any window so the moisture/air doesnt return back into the basement?
Thanks for the input!
Tags
basement , basement bathroom , bathroom , ventalation
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
worth it in terms of energy savings to replace bathroom exhaust fans? ChrisJJ Electrical 0 06-14-2011 10:17 AM
How can I vent a bathroom exhaust fan out of the window without it looking hideous? mizrachi HVAC 11 12-01-2010 08:14 PM
Basement bathroom exhaust fan install krusty HVAC 5 09-15-2009 07:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
