Bathroom Vents: Wall-mounted Vs. Ceiling Mounted - HVAC - DIY Chatroom Home Improvement Forum
Old 12-31-2011, 01:33 PM   #1
Bathroom vents: wall-mounted vs. ceiling mounted
Hi, All, I am about to remodel both of my bathrooms. Currently they are using ceiling mounted exhaust fans. But I remember reading from somewhere that the wall-mounted one is a lot more efficient 'cause it only has to move the moist air less than 12". I am tempted.
What is your take between the two?
htabbas is offline   Reply With Quote
Old 12-31-2011, 01:38 PM   #2
Rewards Points: 13,690
The only time I've seen wall mounted vents is in old mobile homes. There ugly and it's like having a big hole in the wall for air to leak out of.
Some of the new fans look just like light fixtures.
Old 12-31-2011, 01:44 PM   #3
the termination should have baffles or a door that is activated by the fan when it turns on, so a air leak is very likely not to happen, and I agree that it is much more efficient in the fact that the "exhaust" will not have to travel far, but the air your are trying too remove is warmer then room temperature, so as we all know hot air rises, therefore the best results would be achieved from a ceiling mounted fan.
harleyrider is offline   Reply With Quote
Old 12-31-2011, 01:47 PM   #4
MarginallyQualified
Rewards Points: 2,464
Unless there is some reason why you CAN'T mount the far more common modern exhaust fan in the ceiling and properly vent from there...
I can't see any reason to not use one (you also have the light feature).
hth
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 12:30 PM
Bubbling paint on ceiling caused by damp bathroom floor garv19 General DIY Discussions 4 04-10-2010 07:38 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Ceiling mounted clothes rod (one side wall mount, one side ceiling mount) DCA General DIY Discussions 9 08-17-2009 10:13 AM
Dark color & downlighting to reduce ugly ceiling in downtown loft bathroom? fredonian Painting 3 08-17-2009 09:20 AM
