Bathroom Venting - HVAC - DIY Chatroom Home Improvement Forum
Old 12-13-2011, 11:02 PM   #1
Bathroom Venting
I am trying to properly vent my bathroom vent/heater with very little space. The existing 4" flexible metal tubing runs horizontal from the vent/heater in the ceiling, then down to an exterior wall cap. I have 4" from the outside wall to the interior drywall and the flexible metal tubing sticks out too far, past where I want to hang my drywall. (There was a header previously that hid this vent, but now the header is gone). Is there a 90 degree piece of sheet metal that does not extend past 4" that I can use, connecting the exterior wall cap and connector duct to the rest of the flexible metal tubing? OR can I use plastic flexible coil and smoosh it towards the exterior wall?
garysacco3537 is offline   Reply With Quote
Old 12-14-2011, 08:44 AM   #2
Rewards Points: 582
get us somekind of pictures.....would help ...
Old 12-14-2011, 03:57 PM   #3
Bathroom Venting
Without the long windedness: can I put a plastic flexible pipe (4") right onto the exterior wall cap and bend it 90 degrees?
Old 12-15-2011, 11:53 AM   #4
Bathroom Venting
Need anyone's help on this. Can I cut the connector duct that extends 8" from the outside wall cap to about 4" long? THe flexible tubing then will be connected to this shorter connector duct, going to the bathroom vent. Again, I am trying to fit this ALL into the wall, behind the drywall, but the 8" connector duct was sticking out too far. Thanks!
Old 12-15-2011, 12:38 PM   #5
Rewards Points: 582
if you can't get picture....Ithink you want to cut the dryer vent to shorten it.. they come about 12" long new you want to cut it 3-4 " shorter then put 90 on .....go for it ....should work.....if no other way....will it be accessable....Ben
Bathroom Fan Venting PeteW HVAC 17 09-05-2011 10:12 AM
Bathroom Remodel Venting JPWMU Plumbing 0 05-16-2011 09:23 AM
3rd Floor Bathroom Not Venting FEDERAL GOON Plumbing 4 06-15-2008 08:35 AM
Bathroom venting g1246 Remodeling 4 04-11-2007 05:30 PM
