Bathroom Ventilation Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 01-11-2010, 10:44 AM   #1
Bathroom ventilation problem
I had a house built for me about 5 years ago. Unknown to me, the builder did not vent my bathroom fans properly...they vented into the attic. So, I began getting a mold issue in my attic.
To make a long story short, this was corrected and the vents were vented out of the eaves, however they used flexible duct and it wasnt insulated (rigid isnt that good of an option because of the amount of clearance and length of run to the eave (at least 15 feet). A good amount of water built up into the duct so I tried to drain the water which resulted in the flexible duct ripping. I have a number of questions. First, should I proceed with the same method if I can eliminate all low spots in the duct and insulate it? Secondly, my fan is only 50 CFM; is that too small of a fan to push air that distance?
Lastly, I noticed this morning some frost that built up on the eave of the west facing wall. It has been very cold here with a lot of snow. Is this ok or does that need remedied as well?
jreed is offline   Reply With Quote
Old 01-11-2010, 03:26 PM   #2
An old Tradesmen
Rewards Points: 6,892
Code requires min 75CFM if its an intermittent fan(not ran 24/7).
Use insulated flex duct.
Some frost/ice is ok at colder winter temps.
Old 01-11-2010, 03:34 PM   #3
Thanks for the info. Is this what you would use:
http://www.lowes.com/lowes/lkn?actio...T4W&lpage=none
Old 01-11-2010, 03:50 PM   #4
An old Tradesmen
I would use the type with the silver foil face.
but you can use that.
ceiling paint in bathroom gorilla325 Painting 15 09-10-2012 06:07 PM
Bathroom mold problem ACB123 General DIY Discussions 4 08-18-2009 12:08 PM
Electrical "arcing" problem? morden5b Electrical 17 12-17-2008 06:10 PM
bathroom moisture / ventilation problem syd barrett HVAC 1 11-19-2008 05:11 PM
Bathroom Problem 1-homeimprovement General DIY Discussions 3 09-13-2007 05:59 AM
