Bathroom Ventilation - HVAC - DIY Chatroom Home Improvement Forum
Old 10-01-2012, 12:40 AM   #1
Question
Bathroom ventilation
Would like to know the diference between an External wall mounted dryer
vent & a External wall mounted bathroom vent.
Noticed when I went to Home Depot that the vents in stock were listed
as dryer vents.
What are the design features that distinguish them as either a dryer vent & or a bathroom vent.
Can they be enterchanged.
Could not get an answer fro Home Depot.
Thanks Jim.
Jim Baughman is offline   Reply With Quote
Old 10-01-2012, 08:18 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Are you referring to "Vent Covers"?
- Build Well -
Old 10-01-2012, 08:33 AM   #3
Rewards Points: 13,274
Both will work fine. I would not use the ones with the luvers, Use the one with round flapper instead.
The louvers start to stick over the years.
Old 10-01-2012, 09:10 AM   #4
Rewards Points: 1,294
Around my neck of the woods I would recomend the louvers over the flappers. The birds here have gotten smart enough to figure out how to open the flaps and get in to build nests
danpik is offline   Reply With Quote
Old 10-01-2012, 10:48 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,120
I've used both.
I think the choice depends on where the outlet will be. If it's going to be up high where you can't run into it with your body...flapper is better. If it's down low, the hood over the flapper sticks out and is subject to damage (especially with my kids). In that case, I think the louver is better.
Old 10-02-2012, 07:46 AM   #6
Rewards Points: 3,130
Besides the louvers vs. flapper, bathroom and dryer vents are almost always different sizes. The typical bathroom vent is 3" diameter, while every dryer vent I've ever seen is 4" diameter. There are 4" diameter bathroom vents (I have them), but my fans are far upscale from the $10 Broan units you typically see.
Old 10-02-2012, 10:48 AM   #7
JOATMON
ddawg16's Avatar
Oh, you mean those white ones that sound like a P51 taking off?
Yea....mine is 4" as well...quiet enough that you can't hear it over the noise of the shower.....or if your even in the hallway. Had to install a occupancy sensor seeing how my kids (and wife) have not learned how to turn off lights.
Old 10-02-2012, 11:07 AM   #8
Rewards Points: 2,210
Even got ones with a styrofoam ball in them, seals of the cold winter winds.
mae-ling is offline   Reply With Quote
Old 10-02-2012, 11:55 PM   #9
Registered User
Rewards Points: 5,216
Use a Type "A" rather than "B" for 50% more air flow: http://www.appliance411.com/faq/dryer-vent-length.shtml
The louvers tend to collect wet lint better, I've found.
Test of different types:
Gary
P.S. Welcome to the forums!
bathroom ventilation LMPD Electrical 3 12-12-2011 02:01 PM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 11:50 AM
BAD ADVICE??? You tell me! Bathroom Exhaust Fan Ventilation firefish317 Plumbing 2 04-20-2010 09:23 PM
Bathroom ventilation / window privacy issue Michael Thomas General DIY Discussions 10 05-26-2009 10:09 AM
Bathroom ventilation and cooling dragon6172 General DIY Discussions 3 05-11-2009 03:40 PM
