Bathroom Vent - Where To Exhaust It? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-24-2013, 08:29 PM   #1
Rewards Points: 173
Current bathroom has no fan. I'm looking to install a new Panosonic one, but I'm not sure if I should exhaust it through the roof or on the side (right of the window)
RCGA is offline   Reply With Quote
Old 04-24-2013, 10:02 PM   #2
Rewards Points: 344
Yes, diffinately put an exhaust fan in the bathroom. IMO, going by your pic, I would prefer going through the roof option as opposed to going out by the right side of window option if you can. Either one would work, and everyone will have their own opinion as to what they think is best.
I do not know your location, it's not in your post. I assume by the bare trees and pine trees you are in a cold weather climate.
My reasoning is this; Properly installed for your geographical area (thinking of winter time), the roof vent option would be no issue at all. The moisture laden air coming from the bathroom will simply rise up and dissipate into the atmosphere. However, this option must be installed properly to work. Duct work properly insulated etc. Expect to pay a little more with going through the roof option.
Coming out by the the right side of window option, or 3 feet from your window area, whatever, you would be pumping the moisture laden air down, and we all know that hot air rises. Possibly going back into the soffit, causing moisture to get under your roof. However, this option would be less expensive and much easier. It's up to you, this is just my opinion.
jmon is offline   Reply With Quote
Old 04-24-2013, 10:28 PM   #3
Rewards Points: 1,192
I'd avoid making any roof penetrations if f you can.
bobelectric is offline   Reply With Quote
Old 04-24-2013, 11:22 PM   #4
Registered User
Rewards Points: 526
I'd put it in the ceiling, next to the light---sink side, exhaust it out the closest gable end. Not side wall mounted.... far from the tub/shower (moisture source). Be sure to insulate/vapor barrier in unconditioned attic space, use straight pipe, pitch toward termination hood.
Gary
Old 04-25-2013, 07:15 AM   #5
Rewards Points: 173
Here is the floor plan. Note that I can't exhaust towards the bottom. But I could go up through the Aric and out above the bedroom closet.
Old 04-25-2013, 09:41 AM   #6
I'm Your Huckleberry
Rewards Points: 2,270
I think you're over thinking this. it's a bathroom exhaust fan, not a supply register. simply get a 4 inch flexible duct specific to an exhaust fan and run it over to the soffit and it's done. but make sure you have the right size fan, needs to be able to refresh 8 times per minute, I believe, so you need to know heigth, width and depth.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 04-25-2013, 09:51 AM   #7
that'll be total cubic feet of the restroom. and then there's the noise level of a fan, called sones, to think about.
Thanks.
Old 04-27-2013, 08:52 PM   #8
Sometimes you need them sones after a good weekend.
Old 04-28-2013, 12:19 PM   #9
Make sure if you vent right next to the window you keep it 3ft away atleast.
k20vteck20 is offline   Reply With Quote
Bathroom Exhaust questions flashinm HVAC 8 03-10-2013 05:37 PM
Bathroom exhaust through roof Dugams Roofing/Siding 28 09-01-2012 02:51 PM
dryer/bathroom vent terminations and window clearances itsnotrequired HVAC 14 04-29-2012 07:55 PM
Wondering if it makes economic sence to replace a bathroom exhaust fan ChrisJJ HVAC 0 06-14-2011 10:36 AM
Venting bathroom vent thru dryer duct jredrocker HVAC 2 09-27-2008 10:25 PM
