Bathroom Vent Insulation - HVAC - DIY Chatroom Home Improvement Forum
Old 12-19-2012, 07:31 PM   #1
Rewards Points: 129
Bathroom vent insulation
When replacing a bulb in my bathroom vent fixture the fixture itself felt pretty cold. Went into the attic and the fixture was covered with insulation. The aluminum ducting is laying between the rafters going to the soffit. The ducting is on top of the attic insulation. Is this correct or should the insulation be laying on top of the duct?
jeepgrady is online now   Reply With Quote
Old 12-19-2012, 08:11 PM   #2
Rewards Points: 744
My bath vent duct isn't insulated. It runs right up to the roof. I do plan on replacing it with an insulated duct, however.
Seattle2k is offline   Reply With Quote
Old 12-19-2012, 08:23 PM   #3
Mine is insulated. I was doing a lot of work in the attic, had a few minutes, and had the materials, so it felt justifiable to me, if only for a small amount of heat savings.
If you use a foil backed insulation and seal it well with some hvac tape, you should be in good shape. I think the big box stores also sell specially designed insulation sleeves for duct work, if you prefer to sacrifice some additional money for an easier install.
myfirstrodeo is offline   Reply With Quote
Old 12-19-2012, 08:36 PM   #4
Rewards Points: 129
The duct itself is insulated. I just want to know whether the duct should be lying above or below the attic insulation batt.
Old 12-19-2012, 08:39 PM   #5
Sorry! I would just as soon leave it on top...
Old 12-20-2012, 07:30 PM   #6
Insulating the duct isn't necessarily to prevent heat loss, but rather to prevent condensation in the duct. Drawing warm moist air through a cold duct will cause water to collect on the duct walls. In the summer with a non-insulated duct this probably wouldn't be much of a problem, but in the winter with a cold attic (I hope your attic isn't warm in the winter) it can become a problem.
BOUTYM is offline   Reply With Quote
Old 12-21-2012, 07:24 PM   #7
Mine is on top of the attic insulation. Makes it easier if you have to check it later for whatever reason.
okeefferp is offline   Reply With Quote
Old 12-21-2012, 07:28 PM   #8
Roofmaster
Rewards Points: 2,172
I would put it under the insulation so the moist hot air does not condense and freeze on its way to the soffit.
Old 12-21-2012, 08:15 PM   #9
Just pick up some good duct insulation and wrap the thing. I have a big inline that ventilates two bathrooms and I have it wrapped from the inlets all the way to the roof vent, including the fan itself.
Can I use one roof vent for 2 bathroom exhausts fans? P550 General DIY Discussions 19 05-18-2014 10:41 PM
new bathroom vent trips GFI when switch is turned off. Mike in Arkansas Electrical 3 11-16-2011 10:43 AM
Exhaust Vents - Bathroom and Stove trophywalleye HVAC 0 03-19-2011 11:14 PM
How to cut vinyl siding to vent bathroom fan? db_9 General DIY Discussions 9 11-13-2009 01:58 AM
Any warnings for insulation in a bathroom? jayp Building & Construction 11 08-03-2008 10:35 PM
