Bathroom Vent Fan Outlet - HVAC - DIY Chatroom Home Improvement Forum
Old 03-23-2013, 10:20 PM   #1
Rewards Points: 87
bathroom vent fan outlet
I am finishing my basement bathroom. It needs a fan. There is window in the middle of the exterior wall. There is no way to make the vent outlet 3ft away to any opening of this house if I just terminate the vent on the exterior siding.
Two questions:
1. Can I turn it up from outside siding and run up 3ft to meet the 3ft requirement?
2. Can I use 4" PVC pipe for this purpose?
diy001 is offline   Reply With Quote
Old 03-23-2013, 10:50 PM   #2
Rewards Points: 232
1) Not sure, but I think u should be all right to terminate right out your exterior siding as long as there are no combustables. U say it's just a bathroom fan. How close to window, soffit or door are u talking?
2) PVC can be used, kind of an over kill. U could just use regular metal pipe as well. Up to u, they are both acceptable. Let's see what the pro's say.
jmon is online now   Reply With Quote
Old 03-24-2013, 06:39 AM   #3
Roofmaster
Rewards Points: 2,172
OK, why is there no way to run the vent 3 feet away from the window? What size are your first floor joists?
Old 03-24-2013, 11:06 PM   #4
Rewards Points: 87
just measured, it is about 9". left of the room is stairs so cannot go that direction. go right is also almost impossible with those drain pipes. That's why I am thinking run up outside the sidling to satisfy the 3ft requirement.
Old 03-26-2013, 09:25 AM   #5
Rewards Points: 87
Got a code book from library. It turns out there is no such 3ft requirement for bath fan. It is for dryer exhaust.
Old 03-26-2013, 09:35 AM   #6
Roofmaster
You mean a clothes dryer?
Old 03-26-2013, 02:03 PM   #7
Rewards Points: 87
yes, I updated.
Heater register vent in bathroom moving up ohman HVAC 2 09-15-2012 07:34 AM
Bathroom venting near gable vent? jdhoskins Kitchen & Bath Remodeling 5 08-10-2011 10:54 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Bathroom vent damper staying open BlueBSH HVAC 2 12-27-2010 07:11 AM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
