Bathroom Vent Fan -- All Concrete Walls - HVAC - DIY Chatroom Home Improvement Forum
Old 03-07-2012, 10:35 AM   #1
Bathroom vent fan -- All concrete walls
I am finishing my basement and have run into a problem. The obvious location for the bathroom is under my front porch and completely encased in concrete. I want to install a shower but how would I install a vent fan? Can you do that through the concrete walls? If so, can I use a small vent pipe?
Thanks.
Spade
spadehigh is offline   Reply With Quote
Old 03-07-2012, 06:33 PM   #2
Thanks.
Spade
you might have to rent a drill to bore the hole through the wall so you can run a 3 or 4" pipe. and then use a roof jack on the side wall. Paul
paul52446m is offline   Reply With Quote
The Following User Says Thank You to paul52446m For This Useful Post:
ben's plumbing (03-07-2012)
Old 03-07-2012, 07:13 PM   #3
AHJ
Sure, Nothing wrong with that, might run into rebar, but that can be cut through
AHJ is offline   Reply With Quote
Old 03-07-2012, 08:54 PM   #4
Your right it can be cut. a hammer drill and saws-all can do it. I think i have done it a few hundred times paul
Concrete (Cinder) Block Barebones Home : Seeking Advice granadaCoder Building & Construction 11 08-11-2012 07:03 AM
Dryer vent thru concrete steps john620 Building & Construction 5 01-31-2012 04:19 PM
Bathroom Remodel - Resurfacing Plaster over Concrete Block itcanadian Remodeling 2 05-30-2011 10:10 AM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 09:57 AM
