Old 02-15-2011, 10:02 PM   #1
Bathroom HVAC duct
Im remodeling my second floor bathroom. I have just completed the demo and new electrical pulls, but before i put my new subfloor in I need to move the HVAC duct.
Right now it is coming from the wall about 6 inches off of the Floor. The problem is the whirlpool tub that I have is larger then the tub that was removed, and it will cover the vent. I can't move it to the side because it will run into the window supports, if i go past the window supports it will be right behind the toilet.
So my question is, What do you guys think about Floor HVAC Vents in the bathroom? Im wondering because it will be close to the tub!
1stclasso is offline   Reply With Quote
Old 02-16-2011, 12:54 AM   #2
HVAC Supermodel
unicursalhex's Avatar
Bathroom HVAC duct
Floor is fine, its most common. I try to put em below the towel rack
unicursalhex is offline   Reply With Quote
Old 02-27-2011, 10:30 AM   #3
Bathroom HVAC duct
I have been searching online for the procedure on this and i cant find one.
How do i support the vent? if there is a lip on it, where does it mount? I plan on 12" tiles on the floor.
Anybody know of a good tutorial for this?
Old 02-27-2011, 10:40 AM   #4
User
Bathroom HVAC duct
Keep in mind when considering your floor location on how it throws (direction and velocity) as you don't to step out of the bath or shower and have it blow on your wet body.
No matter how hot that air it will feel cold and uncomfortable.
Subcooled is offline   Reply With Quote
Old 02-27-2011, 10:50 AM   #5
Bathroom HVAC duct
Yes I have thought about that, but its the only choice I have that will give it a non impeded path.
Old 02-28-2011, 06:39 AM   #6
the Musigician
DangerMouse's Avatar
Bathroom HVAC duct
I was told floor vents in the bathroom or any wet room are against code and not allowed.
6" off the floor toe kick registers were the only thing I could install.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 02-28-2011, 06:59 AM   #7
Super Moderator
Bathroom HVAC duct
DM
That must be a local code--or a new one--Floor vents in bathrooms are common in this area.---I like the idea of wall vents in a wet area--Mike--
Old 02-28-2011, 07:07 AM   #8
the Musigician
Bathroom HVAC duct
When this was a mobile, there was a floor vent right next to the toilet!
When I was talking to the inspector about where to put the new vents, he said I cannot put them on the floor because of 'Legionnaires' disease" if water gets down in the ducts.... go figure....
DM
Old 02-28-2011, 02:13 PM   #9
Bathroom HVAC duct
I have put vents underneath the vanity cabinet and cut a vent into the toe kick to let the heat out from under the cabinet before in a bathroom. Works good and no vent to stub your toe on.
HVACDave is offline   Reply With Quote
Need help with HVAC duct in basement... tbuchner HVAC 1 01-12-2011 07:16 PM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 07:20 AM
hvac duct through fire wall acerunner HVAC 12 07-06-2010 09:44 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 10:29 AM
kitchen wall and bathroom fans sharing duct amakarevic Building & Construction 5 06-11-2008 01:13 AM
