Bathroom Fan Size - HVAC - DIY Chatroom Home Improvement Forum
Old 05-03-2012, 08:25 AM   #1
Bathroom Fan Size
I am installing a new fan in an existing bathroom. The bathroom is 8' x 5'. There is a bathtub, sink & toilet. No shower. I will run a 3" duct (see other thread, why) down the wall(6ft) then outside(3ft) with 2 90's or down the wall with 1 90 turn & 10 ft to outside. Using 3" ducting I don't have many fan options. Any suggestions on what size is required?
wndnns is offline   Reply With Quote
Old 05-03-2012, 09:45 AM   #2
Rewards Points: 13,458
http://www.checkthishouse.com/3978/b...an-sizing.html
Old 05-03-2012, 09:56 AM   #3
guidelines that recommend approximately 8 room air exchanges per hour
Maan, that's gonna be a cold bathroom! Make sure you are buying a vent with at least two speeds. Hi speed for turbo-freezing jet-like 8 exchanges per hour, and low speed for comfy silent bathing at ~3 per hour rate.
sqslist is offline   Reply With Quote
Old 05-03-2012, 10:25 AM   #4
I guess my question basically is will a 50 CFM meet my requirements or should I use a 70 CFM. My concern with the 70 is the noise level but if a 50 is too small I can live with the noise.
Old 05-05-2012, 11:38 PM   #5
Rewards Points: 150
Late to the party but...50 cfm should do it nicely...with 4" pipe. The static pressure will be greater when using 3" pipe. Turns in the piping also increase static pressure. As static pressure increases, cfms decrease.
I did read your other thread. Have you considered venting through the roof? Here is a flashed roof cap that will work well (I installed this very one. It's well constructed and low profile). You install the jack and seal the pipe init from the underside:
http://www.grainger.com/Grainger/BRO...905?Pid=search
If you have doubts about how well your ventilator will perform with your planned pipe size and run, call the manufacturer. Give them the details of your pipe run (i.e., length, pipe size, 90 degree turns). They'll be able to tell you what your cfm rating will be for the static pressure your pipe run will produce.
rightit is offline   Reply With Quote
Old 05-06-2012, 09:45 AM   #6
Thanks for the reply. I really don't want to go up in the attic or cut into my shingles at this time. So my problem is the 3 inch duct and whether 50 CFM is enough. But your advice in calling the manufacture is good advice (Broan)
Old 05-06-2012, 11:03 AM   #7
If I were you, I use 4" and 70cfm. I have a 6x7x 9high bath room with 3" and 50 cfm. It is too small.
clocert is offline   Reply With Quote
Old 05-06-2012, 11:08 AM   #8
Thanks. I will need to use the 70CFM then. As I will be using 3". 70 has been the largest 3" size that I have seen.
Tile size pros and cons for bathroom wall. Jim F Kitchen & Bath Remodeling 12 02-29-2012 10:11 AM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 10:50 AM
Bathroom fan replacement reveals...a mess merlanvp Electrical 0 07-25-2010 08:00 PM
Basement bathroom size? BlueBSH Building & Construction 1 06-28-2010 08:03 PM
Second level / attic bathroom size moneymgmt General DIY Discussions 2 05-02-2007 07:32 AM
