Bathroom Fan With Pvc Exhaust Pipe? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-26-2013, 04:19 AM   #1
Rewards Points: 452
Bathroom fan with pvc exhaust pipe?
4" sewer pipe.
Half the price of aluminum duct per foot.
Max airflow compared to corrugated flex duct.
If you were going to install rigid exhaust pipe for max airflow, this plastic sewer pipe would work well, wouldn't it?
Lowes and home depot sell them cheap.
http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
http://www.homedepot.com/h_d1/N-25ec...1#.UQOsrL_7KHc
pman6 is offline   Reply With Quote
Old 01-26-2013, 10:23 AM   #2
Rewards Points: 13,748
Should work fine.
If it's in an attic insulate it so it's less likly to form condinsation.
Old 01-26-2013, 12:32 PM   #3
Roofmaster
Rewards Points: 2,210
Joe's right, as usual. You can usually just run it under the attic insulation on the warm side. Hook up with a Fernco, put some SS screening on the outside
Old 01-26-2013, 02:17 PM   #4
Not liking the screen idea, a reguler siding block will work with some foil tape on it. It would just look better to me anyway.
Old 01-26-2013, 06:17 PM   #5
Rewards Points: 452
Something interesting.
This cheap sewer pipe is made of HDPE, which I've read is a good insulator.
http://www.isco-pipe.com/products-an...hdpe-pipe.aspx
So you may even be able to skip buying a roll of insulation.
I'm running the exhaust to a soffit, so I'll be experimenting with this to see if there is any condensation.
If there is no condensation, this would be max performance on the cheap !
New bathroom soil pipe connection - External OK? tpagel Plumbing 3 01-14-2013 05:00 PM
Exhaust Vents - Bathroom and Stove trophywalleye HVAC 0 03-19-2011 10:14 PM
Water Dripping Out Bathroom Exhaust Hood Caulk? leftygroove General DIY Discussions 7 03-08-2011 07:53 PM
I have a leak in a 7 inch pipe running from my kitchen to my bathroom sully2310 Plumbing 3 05-23-2010 10:23 AM
Installing bathroom sink - drains off slightly less than pipe diameter lazzlazz Plumbing 17 05-21-2010 05:12 PM
