Bathroom Fan Damper Missing Is Roof Vent Damper Enough?? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-10-2011, 05:08 AM   #1
Rewards Points: 145
Bathroom fan damper missing is roof vent damper enough??
i had an energy audit done and notice one of my bathroom fans spinning backwards when they had the negative air pressure on.
I took apart all my fans and none have the damper directly behind the fan (as do the ones that u brand new) I guess the fan that was spinning has a damaged roof damper. I assume the house has roof vent dampers on all the exhaust fans it is 13 years old.
So my question is the roof damper enough or should i have a damper directly behind the fan also..
http://www.centralvacuumstores.com/B...-Connector.php
wantboost is offline   Reply With Quote
Old 11-10-2011, 06:35 AM   #2
jkv
The auditer should give you a complete report on your house, the fan should be included in that report. If your fan was going backwards when they did the blower door test then you have leakage there and should replace the fan and seal it. You can ask them on the CFM size you need for the size of the bathroom. I can give you more info. if you have the report.
jkv is offline   Reply With Quote
Old 11-10-2011, 03:04 PM   #3
Rewards Points: 145
none of my fans have the plastic dampers behind it and only 1 was spinning.
He didnt confirm what the problem was but i guess i should look if the connection behind the fan is not proper or i guess the roof damper is bad?
Old 11-10-2011, 03:38 PM   #4
Rewards Points: 6,652
Dampers are something that was never put in the past, for baths. Just go to the local hardware store and get a inline if able to access the duct up in the attic. If can not access duct, install a new outside vent. Only way to find out if it vents to the roof, is by looking up there, or getting in the attic and following the ductwork.
Old 11-10-2011, 03:44 PM   #5
Rewards Points: 145
I check 2 box stores and they don't sell the fan dampers
Old 11-10-2011, 04:29 PM   #6
You will never find them under that name. They are called "inline duct damper's", also called "Backdraft damper". You will find them where the dryer stuff is in Lowe's, or where the ductwork is.
2 Bathroom fans to 1 roof vent? theatretch85 Kitchen & Bath Remodeling 13 12-15-2013 08:25 AM
New Roof marknok Roofing/Siding 4 08-06-2011 11:41 AM
Vent for basement bathroom group chadmills Plumbing 1 10-29-2010 03:03 PM
Bathroom vent out /Flat roof grzy1958 Roofing/Siding 1 09-27-2010 07:41 PM
Can I vent a bathroom fan in the basement? Red Squirrel Building & Construction 6 09-22-2010 11:53 AM
