Bathroom Fan - HVAC - DIY Chatroom Home Improvement Forum
Old 10-18-2011, 04:18 PM   #1
Bathroom Fan
My bathroom fan is dripping water. I'm aware of problems with uninsulated air ducts going thru the attic, combined with cold weather; however, I live in a condo and there is no cold zone attic that my air duct goes through.
I'm on the 2nd floor of a 12 floor high rise. There is concrete between each level and my bathroom ceiling is gyprock. There is approximately 1 foot of space between the ceiling gyprock and the concrete above. The fan air duct runs horizontally to an external wall; approximately 13 feet. The aluminum air duct is not insulated. It's a two room fan design that ventilates the bathroom and kitchen.
Any ideas how to rectify this problem? I'm thinking the fan itself is crap and needs replacing. This could pose a problem though, because the fan casing is mounted to the concrete above the gyprock. I see no way of removing it without tearing down some gyprock, which could be a costly project just to replace a fan.
Teenwolf is offline   Reply With Quote
Old 10-21-2011, 11:38 AM   #2
A junk fan would not cause dripping water by itself - I think you're barking up the wrong tree by thinking of replacing it. Is the problem cold-weather related, or does it happen all year round? If you don't have a backdraft damper, or a malfunctioning one, cold air could be coming backwards through your duct + cooling the aluminum air duct enough to cause condensation when you run the fan.
One way to fairly easily fix this is to make sure the duct slopes towards the outside instead of toward the fan.
teststrips is offline   Reply With Quote
Bathroom to Laundry Room to Bathroom bcatanz10 Remodeling 2 10-10-2011 09:45 PM
Wondering if it makes economic sence to replace a bathroom exhaust fan ChrisJJ HVAC 0 06-14-2011 10:36 AM
1886 Eastlake - add upstairs bathroom or expand downstairs bath?? TOTALN00B Plumbing 1 05-14-2011 09:54 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
