Bathroom Exhaust Questions - HVAC - DIY Chatroom Home Improvement Forum
Old 03-09-2013, 10:19 PM   #1
Bathroom Exhaust questions
I just purchased a house and the two bathrooms are back to back. One of these has a vent that just goes straight into the attic (no ducting). The other bathroom doesn't have a vent. I'm going to install a vent in that bathroom, but I'm wondering if I can combine the fans into a single exhaust point.
They are back to back against one wall so a soffit style exhaust would be the closest way out and seems like the easiest to install. Are there any exhaust vents that have dual connections? I know a T fitting is out because it would just push air from one vent to the other, but what about a Y connector? Would it be better to go straight up about 5 feet and exhaust through the roof?
The attic also has 2 triangular shaped vertical vents (approx 4 ft wide and 3ft tall) that have a screen on the inside and louver style wood strips on the outside. Could I just connect the vents to the screen with foil tape to vent them outside? Thanks in advance.
flashinm is offline   Reply With Quote
Old 03-10-2013, 11:07 AM   #2
Roofmaster
Rewards Points: 2,210
Triangular vents? Post some pictures. I would not combine vents, you will blow stink from one BR into the other.
Old 03-10-2013, 11:29 AM   #3
Rewards Points: 2,516
Fantech sells an inline fan with two ceiling grills.
hammerlane is offline   Reply With Quote
Old 03-10-2013, 12:25 PM   #4
Looks like this. They're just passive vents that help cool the attic.
Old 03-10-2013, 02:04 PM   #5
Roofmaster
Sorry, I lost you. Those are called gable end vents. You dont say where you are from, but if you are in a region where it gets cold in the winter, you have to be concerned about condensation in the winter time. You want to keep the exhaust pipes from the bathroom on the warm side of the insulation, not hanging up in the attic like the illustration you have posted. The fans should exit out a wall cap in your side wall, not to your gable end vents.
Old 03-10-2013, 02:08 PM   #6
Rewards Points: 13,694
Panisonic as sells them.
Old 03-10-2013, 04:27 PM   #7
I live in Dallas so it's pretty mild in the winter, but it does get cold. Venting through the wall would require knocking out brick and is more than I want to tackle. Venting out an overhang vent seems like the easiest solution, but I'd rather only have to cut out one vent. I could elevate the portion of the duct that attaches to the fan just a little bit and have it go downhill toward the vent so any condensation would flow toward the vent. Or I could insulate the ducting somehow.
Old 03-10-2013, 05:13 PM   #8
Roofmaster
Sounds good. So I guess the fan pulls on both bathrooms at the same time. I like the remote fan to reduce noise. I have installed a few radon reduction systems with fans like this and you don't even know they are running.
Old 03-10-2013, 05:37 PM   #9
No, I'm talking about 2 fans that I want to join to one exhaust point either by cutting a hole in the roof, overhang or using the triangular vents already in place.
Small Bathroom remodel questions and step order Velvis Kitchen & Bath Remodeling 0 04-26-2012 04:36 PM
Bathroom exhaust fan ducting wndnns HVAC 6 04-05-2012 03:09 PM
Bathroom Exhaust Fan ArmColor Electrical 3 02-13-2012 10:22 AM
Bathroom Exhaust Fan Duct Sizing Lyndon HVAC 6 02-06-2012 07:35 AM
Bathroom Exhaust Fan Questions AllGoNoShow Remodeling 10 11-11-2006 07:59 AM
