Bathroom Exhaust Options - HVAC - DIY Chatroom Home Improvement Forum
Old 09-28-2009, 11:14 AM   #1
Bathroom exhaust options
My bathroom had a ceiling exhaust fan that needed replaced. I did it once already and it was painfull... VERY little space in my attic to do properly. Here is my q. I was going to install an inline duct fan into my wall that will directly vent to the outside. Easy to replace if needed in the future. I'd like to install it above my bathroom window, but there is very little room. I know its not the best option, but would installing it approx 2 feet off of the ground below the window be ok? Or I could even install it right in the shower stall area. I'd have a plastic cover over it so there'd be no chance of getting zapped. I'm guessing the 'in the shower area' idea is not the safest option.
thoughts?
thanks
fjacky is offline   Reply With Quote
Old 09-28-2009, 04:01 PM   #2
An old Tradesmen
Rewards Points: 6,464
In the shower area, you need to have it connected through a GFCI.
Warm moist air rises. So mounting it under the window may make that it doesn't work as well as you would like.
Old 09-28-2009, 05:19 PM   #3
I know, but I was hoping it would be a lot better than not having any fan. The fan is quite powerful. 240 cfm
Old 09-28-2009, 06:08 PM   #4
An old Tradesmen
Thats 240CFM at probably 0" static pressure. With the door closed, you'll have a lot of static pressure.
And any air it draws out. Will come from under the door(when its shut) stay near the floor, and not mix with the moist room air.
Basement bathroom exhaust fan install krusty HVAC 5 09-15-2009 08:41 PM
Bathroom exhaust fans PirateKatz HVAC 7 11-18-2008 04:09 PM
Bathroom Exhaust Fan Ducting drtpdee HVAC 1 03-03-2008 07:47 PM
Bathroom Exhaust Fan Questions AllGoNoShow Remodeling 10 11-11-2006 08:59 AM
