Bathroom Exhaust Fan Not Pulling Much Air - HVAC - DIY Chatroom Home Improvement Forum
Old 06-22-2013, 12:21 PM   #1
Rewards Points: 160
Bathroom exhaust fan not pulling much air
I noticed when taking a shower, that the exhaust fan isn't pulling very much. I cleaned the vents and that didn't help.
I decided to check out the attic but there is blown in insulation everywhere. There is a flexible pipe from the vent, but I dont see it terminating any where. I figure there should be some sort of vent on the outside of the house?
word2yamutha is offline   Reply With Quote
Old 06-22-2013, 12:37 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,102
Yeah, it should terminate thru a sidewall or the roof. Need to crawl up in the attic and see if it is kinked, disconnected or never installed properly. the fan motor will slow down with age also. remove the cover and see if it is full of dust on the fan/blades also.
Old 06-22-2013, 12:44 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,376
Check the back draft flapper... they often stick closed.
MTN REMODEL LLC is online now   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Gymschu (06-22-2013)
Old 06-22-2013, 01:29 PM   #4
Rewards Points: 160
Well I tried to take a picture of where it terminates but its blurry. It looks like it just go straight into the insulation guess that explains the restrictive flow.
Bathroom exhaust fan not pulling much air-20130622_120742.jpg   Bathroom exhaust fan not pulling much air-20130622_121603.jpg
Old 06-22-2013, 01:34 PM   #5
Not sure I can see either, and I'm not quoting any code here, but if it does not terminate outside, it should probably run to about 12" away from a roof vent... gable vent or ridge vent.... that's to protect from humidity build-up in your attic
yuri (06-22-2013)
Old 06-22-2013, 01:49 PM   #6
Hvac Pro
yuri's Avatar
It should terminate outside or moisture in the attic is NEVER a good idea. Probably got buried when they blew in the insulation.
Old 06-22-2013, 03:47 PM   #7
Rewards Points: 160
Yeah the master bathroom vent is the same way as this one. Well I plan on getting rid of the blow in insulation. That should be fun......
So what is the best way to terminate these vents? Im thinking the side of the house would be the easiest, as I dont feel comfortable putting a hole in my roof.
Old 06-22-2013, 03:59 PM   #8
Yuup...
Old 06-24-2013, 01:08 PM   #9
listo's Avatar
Rewards Points: 93
You sure that's not venting out your soffit?
How come your getting rid of the blown in? What are you replacing it with?
listo is offline   Reply With Quote
Old 06-25-2013, 12:20 PM   #10
Rewards Points: 160
We have a continuous soffit venting around the house, but Im not sure if that is enough.
The only reason I would be removing the insulation is I see some mold growing on it. I can't see the rafters from all the blown in insulation as I dont want to fall through the drywall lol
Old 06-25-2013, 12:49 PM   #11
Hvac Pro
yuri's Avatar
the reason you got mold on it is because the bathroom fan got it wet with moisture and you may also need some better ventilation for the attic and need some local advice on the amount and best methods for your area. may not need to replace all of it just the obvious part but what a pain in the buttski that is going to be.
Old 06-25-2013, 02:45 PM   #12
Rewards Points: 160
Yeah thats why I thought about just removing the blown in insulation because its just a pain in the butt. I also need to do some rewiring up there and everything is covered up by it. At least the good news is some of the insulation is tax detectable about 500 bucks worth.
Old 06-25-2013, 03:00 PM   #13
Rewards Points: 6
Use a small leaf rake to create a path in the insulation so you can see the joists. It works great to put it back in place when you're done as it won't compact it.
Dan
djlandkpl is offline   Reply With Quote
Old 06-30-2013, 06:19 PM   #14
Rewards Points: 160
Well I spent some time in the attic and posted a better picture. There are no leaks in the tubing, no mold and it gets decent air flow. The unit only exhaust at 50cfm its a broan 668.
The tubing dangles above the soffit, which I'm guessing isnt the proper way. The soffit wasn't blocked by any insulation. Would buying a higher quality vent help solve this problem?
Old 06-30-2013, 06:46 PM   #15
Hvac Pro
yuri's Avatar
probably want a 80-100 cfm unit. my 150 cfm HRV which does 3 rooms takes 20 mins to clear the steam from the bathroom. 50 cfm/room. when I had the old conventional 80-100 cfm unit in my apts. they sucked it out in 1/2 the time. it can be vented thru the roof, just talk to a reputable roofer about how and get him to install the vent kit. saw it done on " dis ole house hour" and it is not that big a deal.
google; roof bathroom vent and hit Images
Can I put my bathroom exhaust fan outlet where I want to? danielrg HVAC 9 04-07-2013 08:44 AM
Wondering if it makes economic sence to replace a bathroom exhaust fan ChrisJJ HVAC 0 06-14-2011 11:36 AM
adding can lighting and bathroom exhaust fan to aluminum wired house matjam68 Electrical 2 03-22-2010 11:50 AM
Basement bathroom exhaust fan install krusty HVAC 5 09-15-2009 08:41 PM
Bathroom Exhaust Fan Questions AllGoNoShow Remodeling 10 11-11-2006 08:59 AM
