Old 03-04-2010, 10:42 AM   #1
Bathroom Exhaust Fan
My house built in the early 80's doesn't have any exhaust fans in the two upstairs bathrooms. The bathrooms back on to each other.
Could I install a attic mounted inline fan and draw from both bathrooms at the same time? The total square footage for both bathrooms is about 100. The fan I'm looking at is rated at 100cfm.
Could I control the fan at both bathrooms using timer switches in parallel?
RalphPeters is offline   Reply With Quote
Old 03-05-2010, 04:40 AM   #2
Your bathrooms are about 5x10 each I guess by your dimensions. The typical bath fan pushes 55 cfm...so you're really close for the 2 of them. I don't believe you could wire one fan motor though on 2 timers...you could possibly do it with a three way wiring set up...but..what would you do when 2 people are showering at the same time? Usually the one would backfeed into the other one and cause a dead short as they were both activated.
Affordable7 is offline   Reply With Quote
Old 03-05-2010, 06:21 AM   #3
An old Tradesmen
You'll want a slightly larger fan, around 150 CFM.
Timers will work fine, since you'll be wiring them in parallel.
The Following User Says Thank You to beenthere For This Useful Post:
RalphPeters (03-06-2010)
Old 03-05-2010, 08:20 AM   #4
Have you checked out Fantech?
http://www.fantech.net/bathroom.htm
VelvetFoot is offline   Reply With Quote
Old 03-05-2010, 09:31 AM   #5
Thanks guys.
I'm going to look for a higher rated fan closer to 200 cfm.
Fantech has some interesting products.
Old 03-06-2010, 10:28 AM   #6
Check this one for 2 bathrooms
Fantech CVS 275A
hijack is offline   Reply With Quote
The Following User Says Thank You to hijack For This Useful Post:
Basement bathroom exhaust fan install krusty HVAC 5 09-15-2009 08:41 PM
Bathroom exhaust fan Barry J Remodeling 11 09-06-2009 10:28 AM
Bathroom exhaust fans PirateKatz HVAC 7 11-18-2008 04:09 PM
New wiring and switch for bathroom exhaust fan looking4help75 Electrical 9 06-27-2008 05:15 PM
Bathroom Exhaust Fan Questions AllGoNoShow Remodeling 10 11-11-2006 08:59 AM
