Bath & Kitchen Ducts - HVAC - DIY Chatroom Home Improvement Forum
Old 03-22-2009, 11:03 PM   #1
bath & kitchen ducts
Hi, I need to install a duct system to vent three bathrooms up to the roof and a seperate duct for three kitchenettes. i know the ducts need to be metal. However, does it matter if they are round or rectangular in shape? What size do they need to be? My understanding is that i do not require a roof fan. Any help is greatley appreciated.
zaba is offline   Reply With Quote
Old 03-22-2009, 11:21 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
To simply tell you what size ducts you need is a loaded question.
WHY? Because of all the variables. Here are some.
1. Size of house..sq ft
2. Tightness of house..Does it draft or sealed tight
3. Length of runs
4. Walls/attic/crawl space to penatrate
5. HP/Forced heat
These are just some. Advise is that you have a Pro come to your house and properly size your system..even if you have to pay them.
Don't get me wrong I not trying to be an azz it is just hard to size a system without seeing it.
Good luck
Old 03-22-2009, 11:28 PM   #3
Am I right in that this is a venting question and has nothing to do with with HVAC?
mjbxx is offline   Reply With Quote
Old 03-22-2009, 11:37 PM   #4
what does the V in HVAC stand for?
Old 03-22-2009, 11:45 PM   #5
Plumber101,
I appreciate that. here are more details; the building is not tight, each apt is about 600 sq. feet with the kitchens being 80 and bath about 50 sq. feet. from the ground floor thru the roof is a distance of 35'. i would be starting at the first floor and tying in at the second and third floors to the main duct. the bath fans will be a foot away from the duct and the kitchen exhaust is about 4' with a 90 angle. the heating system is steam.
Old 03-22-2009, 11:58 PM   #6
Rewards Points: 560
My bad. You all are right I assumed it was for conditioned air and not simply a vent.
So lets try this again. You say you are running this into an attic. Are you planning to terminate to exterior?
All vents need to terminate to the exterior and not just into the attic.
Round or square it doesn't matter as long as the size of duct will handle the cfm of the appliance. You can connect individual vents to a common vent as long as the common vent can handle ALL individual appliances that connect will vent properly when all appliances are operated at the same time.
Sometimes it is easier to run a horz run than try to run 35 ft vert
Old 03-23-2009, 12:11 AM   #7
Thank You Sir,
Yes it will be exhausting to the outside. Now for my silly question, how do i calculate the duct size based on cfm of the appliances?
mjbxx: i may have misunderstood your statement, my apologies.
Old 03-23-2009, 12:19 AM   #8
Rewards Points: 560
Try this link
http://efficientcomfort.net/jsp/ResDuct_Web.jsp
Old 03-23-2009, 05:47 AM   #9
An old Tradesmen
Rewards Points: 6,556
May need back draft dampers.
Old 03-23-2009, 05:39 PM   #10
Or fire dampers between apartments. Check with the city.
Mazz is offline   Reply With Quote
Old 03-23-2009, 05:42 PM   #11
Focking good one!
hvaclover is offline   Reply With Quote
Kitchen and bath cabinet source? tmpyankee Kitchen & Bath Remodeling 3 01-06-2009 08:12 PM
Urgent help on leaking bath tub to kitchen surepan Plumbing 6 05-05-2008 06:39 AM
Bath entrance inside kitchen area rich121 General DIY Discussions 1 12-16-2007 06:44 PM
