Bath Fan Exhaust Pipe - HVAC - DIY Chatroom Home Improvement Forum
Old 04-19-2011, 01:14 PM   #1
Rewards Points: 77
bath fan exhaust pipe
what is a good vent pipe to use to run from the bath fan through the attic out of the roof? i want to keep the condensation from happening. its a short run, 10 feet or less.
ive been told pvc, or use metal but to insulate it with foam, like the great stuff in the can? seems like alot of work but id do it if thats the best way.
bryan1282 is offline   Reply With Quote
Old 04-19-2011, 02:36 PM   #2
Stay-at-home GC
They are referring to rigid foam or insulation batts. Keeps the moisture in the exhausted air from condensing on the colder metal and dripping back down into the fan.
Although, I am just about to start a thread regarding the theory behind that.
So what do you guys think? Is there any real benefit to insulating the exhaust run through the attic space? Seems to me, that without any active conditioning of the inside of the exhaust flue, it would become just as cold as the attic surrounding it.
Now if you ran heat through it all the time and then insulated it, I could see the benefit.
Opinions?
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 04-19-2011, 02:46 PM   #3
In colder weather there is the possibility of condensation forming with the pipe warmed from the bathroom air and the colder air in the basement. Years ago they didnt do anything with them, in fact they used to run them out into the soffit. that wasnt a good idea with all that humid air from showers. Use metal pipe and just wrap a batt of insulation around it.
Old 04-19-2011, 02:46 PM   #4
fabrk8r
fabrk8r's Avatar
The purpose of insulating the exhaust pipe is to try to keep as much of the water in the air being exhausted in the form of a vapor, thereby allowing it to be moved to the outside of the structure.
If the exhaust pipe is not insulated, especially in unconditioned spaces, it will become cool enough to condense the water vapor out of the saturated air and cause moisture problems and probably damage.
Normally, 4" diameter galvanized or aluminum smooth wall pipe is used, but some people use PVC now. I personally have never used PVC, but I like the idea of having leak free glued joints and PVC conducts heat less efficiently than metal...it's a win-win!
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 04-20-2011, 06:53 AM   #5
Stay-at-home GC
I just wonder if the insulation has any effect when the air inside the vent has so little conditioning. It seems to me the walls of the vent would become as cold or nearly as cold, as the surrounding unconditioned space unless they were actively conditioned.
Seems the best thing to do would be to turn the fan on 10 minutes BEFORE you start showering, and allow it to run for 10 or 15 minutes after the shower. This would allow the vent run to heat up to the temperature of the conditioned space, before adding moisture to it.
Just me two cents
Old 04-20-2011, 05:05 PM   #6
The dampers are not air tight so there's always warm air rising into the pipe. For a short run like that insulated flex works good as anything.
Old 04-21-2011, 10:26 AM   #7
Rewards Points: 77
i thought of the insulated flex to, i saw richard trethewey use it on ask this old house for a similiar short run. but i figured it might start to sag or something if it got to damp. i have to do some drain work so maybe ill get a little extra pvc and insulate that as well with the batt insulation, thats a good point to that its leak free glue joints. hmmmm, desicions desicions.
thanks guys for the many answers and suggestions.
p.s. im installing a timer for the fan anyway so i would probably turn it on as i was entering the shower and let it run well after, so maybe thats good to.
Old 05-23-2011, 04:10 PM   #8
Rewards Points: 978
i have a similar problem. I would say the run is about 7-8ft. Can I just use elbow and flexible duct to connect to the fan, and then run it through the outside wall? (I do not have actual attic space)
federer is offline   Reply With Quote
Old 05-23-2011, 04:20 PM   #9
Rewards Points: 978
something like this
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Condensation in Gas Furnace Vent Pipe chanco HVAC 2 01-08-2011 04:01 PM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 09:49 PM
Bath Exhaust vs Joinsts On Iowa! Remodeling 3 01-08-2010 03:52 PM
4" to 3" reducer in bath exhaust fan - impact? raz HVAC 4 03-01-2009 03:28 PM
Hooking New Bath into Sewer Pipe jasoncw Plumbing 4 03-04-2008 04:42 PM
