Bath Exhaust Through Outside Wall - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-10-2013, 01:44 PM   #16
747
registered
747's Avatar
Rewards Points: 534
http://www.thisoldhouse.com/toh/vide...630938,00.html
He shows how to vent out a gable end wall.
747 is offline   Reply With Quote
The Following User Says Thank You to 747 For This Useful Post:
JohnnyB60 (02-10-2013)
Old 02-10-2013, 07:45 PM   #17
Thanks for all the advice! I love this forum because I get so many opinions, it helps make an informed decision.
I am thinking about going with this fan:
http://www.amazon.com/Panasonic-FV-1...er+low+profile
It is a small bathroom, so the size should be adequate. I like the idea of using a siding block and a good vent as suggested. Should be a fairly easy install. I will have to run the wiring and switch, but that's no trouble. I do wish I could get a fan directly over the shower, but not possible in this room. The wall unit will have to do.
Maine1 is offline   Reply With Quote
Old 02-10-2013, 08:12 PM   #18
Retired
This all reminded me of a funny story years ago when I used to do residential house wiring that I would like to share.
I contracted to wire a new custom home and the customer was to purchase all the fixtures. Most of the fixtures were very nice expensive ones but they went cheap for the bath fan in the down stairs bathroom. I had finished hooking up everything and went home when I got a frantic call that the bath fan sounded like a Harley Davidson. At the time the only fan that I knew of that was quiet was a NuTone. They were happy with it even though it cost them.
JohnnyB60 is offline   Reply With Quote
Old 02-10-2013, 08:22 PM   #19
I would like to get one of these that was mentioned in an earlier post:
http://www.menards.com/main/heating-...024-c-9502.htm
It looks like they wont ship this item, I would have to pick it up at the store.... It's in Ohio and I am in Maine... Not exactly down the road. I can't seem to find anything like it anywhere else.
Old 02-10-2013, 08:39 PM   #20
Registered User
Rewards Points: 5,514
Joists probably run front to back, remember to stay 3' from any operable window with the termination hood, per most codes. Gary
Old 02-10-2013, 08:48 PM   #21
Well, that might be a problem.., 3 feet would probably bring it into the next room. Theres maybe 2 ft of wall on either side of the bathroom window.
Old 02-11-2013, 10:00 PM   #22
Registered User
2x6 walls on same side of both baths, stacked? For a 4" pipe... how good are you at drywall, or build a chase in the upper bath- corner with shelves or... ? Check with local AHJ, mat let it go.
Gary
Bath Exhaust Fan Timer Switch--2 Switches in Series hammerlane Electrical 5 01-07-2012 06:09 PM
Need Advice - Removing Bath Wall Tile Soxckersfc2002 Kitchen & Bath Remodeling 6 02-01-2010 10:49 AM
What wall switch for bath fan/light/heater? janralix Electrical 6 07-20-2009 11:14 AM
Wall Prep for new bath tub Randell Tarin Building & Construction 6 03-25-2008 11:26 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
