Basic Wiring Question - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-13-2010, 04:24 PM   #16
An old Tradesmen
Rewards Points: 8,228
Your wiring description is a little hard to follow how your connecting your wires.
using supplied transformer. presumming you don't have the automatic humidistat with freeze protection.
Generally. Wire transformer into furnace 120 volt at switch or j box.
Low voltage hot wire from transformer to hum term 1. then hum term 2 to humidistat, humidistat to solenoid, solenoid to common of transformer.
Allows for easier trouble shooting later if ever needed.
Old 01-14-2010, 08:19 AM   #17
Rewards Points: 292
I'm sorry you couldn't follow my 'description' of proposed wiring. I didn't specifically mention, but the model number is the 'A' version. Aprilaire has dropped the A designation; it is now listed as the model 700, so I didn't include it.
I tried to copy a page from the installation manual, but couldn't. So here's a link to it:
http://www.comfortgurus.com/specs/ap...ion_manual.pdf
The only change to their wiring is that the W/G - Cf connections would be connected to the transformer secondary, but routed through the furnace 'dry' contacts.
As I mentioned, I want to avoid making active connections to the furnace board.
V
veesubotee is offline   Reply With Quote
Old 01-14-2010, 12:35 PM   #18
An old Tradesmen
The CF would go to the common of the transformer.
The transformers hot would go to one side of the furnaces hum terminal, and then then other hum terminal would go to the W/G terminal of the humidistat.
Old 01-14-2010, 03:38 PM   #19
Rewards Points: 292
Yes. I didn't know if the transformer terminals were marked. Is the secondary Common terminal so marked? In the event not, would it make a difference if the 2 wires were 'switched' (the 24V I believe is to close the humidifier relay, only)?
V
Old 01-14-2010, 03:57 PM   #20
An old Tradesmen
Generally they are marked R and C on the secondary. If not marked. it won't make a difference.
It will be used to open the solenoid, and power the humidistat.
Old 02-05-2011, 08:53 PM   #21
What was the outcome of the install? I have a similar situation.
I purchased the Desert Spring DS-3200. The supplied transformer is 24VAC @ 300ma.
I decided to not use the supplied transformer since the result is the drum turning 24/7. I have wired it to the W & C which is 24 volts when there is a call for heat.
Everything is working great, but is the way I set this up proper? The way I see it is the extra load is minimal but I am no expert.
I do have the HUM N & HUM H on the control board, so alternatively I could setup a receptacle for the factory transformer.
Advice?
-Lawrence
lkennett is offline   Reply With Quote
Old 02-06-2011, 03:14 AM   #22
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Originally Posted by veesubotee View Post
Thanks to all who responded.
Just one follow-up question: Am I correct that with NO call for heat, there would be zero (0) volts measured between W and ground?
Thanks.
V
right,no call for heat no power to w/white wire
plummen is offline   Reply With Quote
wiring new GFCI breaker question dgates12 Electrical 8 01-07-2010 12:14 PM
Sunset Basic Home Wiring cover is wrong? CareBear Electrical 3 09-03-2009 10:31 AM
Thermostat wiring question beer_geek HVAC 7 05-10-2009 06:49 PM
exhaust fan wiring question (aluminum wire) sflamedic Electrical 6 01-14-2008 04:41 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
