Basement Window Airconditioner - HVAC - DIY Chatroom Home Improvement Forum
Old 04-17-2015, 09:02 AM   #1
Rewards Points: 18
Basement window airconditioner
Hi,
I'm new to the site and need to know if there are ways to rig a typical hopper style basement window (about 33 X 12 1/2" ) to accept a low profile air conditioner. I realize the window portion itself may have to be removed. The finished area of the basement is only about 500 sq ft. and the perimeter walls are well insulated. The unit would face the north. We used to run a dehumidifier but the summers just are too warm here in south Jersey to run it in the summer. The portable units do not seem to be well regarded and I know from use that window air conditioners do the job in rooms that size. Mini splits are too expensive for me. I'd probably hire someone to do the work. Any suggestions on units would be appreciated also. Thanks.
scottfarkus is offline   Reply With Quote
Old 04-17-2015, 06:56 PM   #2
Rewards Points: 3,092
You would probably have better luck with what is now commonly known as a "portable" a/c
Bob Sanders is offline   Reply With Quote
Old 04-17-2015, 08:38 PM   #3
Retired from the grind
gregzoll's Avatar
Rewards Points: 2,962
Or just install a mini split. A whole lot quieter than the room unit pictured above. Along with those units tend to not drain properly.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 04-17-2015, 08:55 PM   #4
Rewards Points: 196
i have a couple of those portable ac units form sharp and they work fine, make sure you get two hoses/ducts they are more effcient that way!
aluminumwelder is offline   Reply With Quote
Old 04-18-2015, 05:41 AM   #5
An old Tradesmen
Rewards Points: 7,430
Frigidaire makes a nice one.
http://www.ajmadison.com/cgi-bin/ajm...3HthoCsNrw_wcB
Old 04-19-2015, 07:27 AM   #6
Rewards Points: 40
[QUOTE=gregzoll;1957393]Or just install a mini split. A whole lot quieter than the room unit pictured above. Along with those units tend to not drain properly.[/QUOTE
I wish I could afford one. Looked into it. $3500 installed requires permitting. Portables have a bad rep. Real inefficient to run. Even more so than a window unit. Was hoping to find someone that did this modification to a basement window to fit in a plug in unit. I see there are units that are about 12" tall that would fit. Just trying to find "that guy" that did the modification to let me in on any pitfalls. Thanks for your responses everyone.
Bonzoso is offline   Reply With Quote
Old 04-19-2015, 08:07 AM   #7
Rewards Points: 830
Is the basement window above grade, or below with a retaining wall running around it?
roughneck is online now   Reply With Quote
Old 04-19-2015, 08:12 AM   #8
Rewards Points: 40
It's in a well drained window well where top of the window is almost flush with grade
Old 04-19-2015, 08:34 AM   #9
Rewards Points: 830
You should be concerned about airflow for a window unit in that case. Not much space in those wells.
The unit needs as much open space as possible to avoid recirculating air.
The Following User Says Thank You to roughneck For This Useful Post:
Bonzoso (04-19-2015)
Old 04-19-2015, 09:11 AM   #10
Hvac Pro
Rewards Points: 466
Very important. If it recircs the air the unit overheats and shortens the life of the compressor and uses a lot more elec = less efficiency/more cost to run. Also the coil gets dirty quicker if it close to ground and if any debris like leaves or paper gets sucked in to the well it plugs the coil.
The Following 2 Users Say Thank You to yuri For This Useful Post:
aluminumwelder (04-20-2015), Bonzoso (04-19-2015)
Old 04-19-2015, 12:22 PM   #11
Rewards Points: 40
Thanks guys. Good to know. No wonder I can't find any info on the net about people doing that. Good thing I always ask these questions and dig before I start tearing into things. The fact that you guys share important info like this is very helpful to us non experts. Looks like it's back to dehumidifier and fans. Cheers!
Old 04-19-2015, 01:13 PM   #12
Rewards Points: 830
Save up and do a quality portable or a minisplit. Preferably a inverter drive mini, I've come to love those things.
Doing a start up on a Samsung heat recovery unit tomorrow.
How to insulate hidden basement window? ngk Insulation 7 02-21-2014 08:03 AM
Replacing basement window (photos inside) untilcomplete Windows and Doors 5 11-26-2013 09:30 PM
Basement window leak alkr Windows and Doors 3 07-08-2012 11:01 PM
Basement Window / Buck Gaps and Leaks ? Carles Windows and Doors 2 07-01-2012 12:06 PM
Basement Window leaking suze0220 General DIY Discussions 8 08-06-2011 09:21 PM
