Basement Vents? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-26-2008, 08:34 PM   #1
basement vents?
I am finishing my basement and I am going to cut in for about five vents, do I need to do a return, and if so will one work or do I need more?
thanks
miller01 is offline   Reply With Quote
Old 12-26-2008, 08:40 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,092
I don't recommend them as it disrupts/lessens the return air movement/air circulation upstairs. You also don't want to be taking cold air from the basement thru the A/C in the Summer. A few hot air vents are usually enough and electric baseboard heaters if necessary.
Old 12-27-2008, 07:46 AM   #3
An old Tradesmen
Rewards Points: 6,066
Supplies in the basement without returns, can cause a negative pressure on the other floors.
In the basement. If you install a return. During the summer, close the supplies. The return will only draw basement return air, if you don't have enough return on the other floors.
Return in basement should be sized to return as much air as you are suppling.
Common mistake made in basements, is not to have enough velocity from the supplies to do a good mix of heated air and basement air.
New poster, looking for advise on heating cooling in basement that is being finished blthomas HVAC 11 12-07-2007 11:07 AM
Air Intake vents....do I need them in basement? yummy mummy HVAC 7 09-21-2007 03:55 PM
Basement heating vents atilla137 HVAC 15 11-22-2006 08:27 AM
