Old 09-23-2009, 02:35 PM   #1
Default Basement return air ducting - flex or metal?
I am in East Tennessee and building the return from a new basement room to the air handler about 12 ft away, also in the basement. I have been told at my local hardware outlet that once I place the return register (which includes an air filter) in the wall of the room I can fabricate a plywood box behind the return register and cut a 6” diameter hole in the back of the box so as to accept a metal collar to which I can then attach 6” flexible ducting to carry the return air back to the air handler. The place where I will tap into the air handler will be just a few feet from the circulating fan. My concerns are a) is it acceptable to use plywood for the return air box behind the return air register b) is it acceptable to use flexible ducting for return air in a basement? c) since the flexible ducting would tap into the main return air ductwork for the house close to the fan, is there any danger of the flex collapsing under the reduced pressure? d) if I use metal pipe returns all the way, wouldn’t this accentuate vibrations/noise?
Thanks for your thoughts.
BasementVirgin is offline   Reply With Quote
Old 09-23-2009, 02:50 PM   #2
old pro
1) There is nothing wrong/unsafe with wood for return air. We use a wood joist space here all the time. Not acceptable for hot air/fire hazard.
2) Flex duct is not so good. Will eventually collect a lot of dust in the valleys and be unsanitary. Metal is better AND I would put a damper in it and close it halfway. You do not want to suck LOTS of air thru it or it will whistle at the register. Also you want to take most of the return air from upstairs.
3) Vibration and noise is not a issue unless your furnace is noisy/vibrating at which point it should be fixed anyway.
Good Luck
Old 09-28-2009, 01:21 PM   #3
Thanks yuri!
I’m now going with the metal pipe plus damper into the top of the wall (which minimizes the pipe length & keeps it high up) & using the space between the studs as a pathway to the filter register at near floor level.
Can you tell me, is it usual to use e.g. caulk/adhesive along the two studs comprising the pathway so that they seal against the sheetrock and minimize unfiltered air leaks into the returning air?
Thanks for the information.
Old 09-28-2009, 04:59 PM   #4
An old Tradesmen
Must be a small area, that your only using 6"
Caulk is normal.
Old 09-28-2009, 07:08 PM   #5
old pro
Caulk is good. I would start with the damper 100% open and blow some cigarette smoke at the register with the furnace running to see how fast it gets sucked in. Close the damper a bit if you feel the velocity is too high. Close it in Summer when the A/C is on. Your choice in the winter how much air you want to remove from the basement. Its a compromise with comfort upstairs. Take too much from downstairs defeats air moving upstairs. I like electric baseboard heaters for basements and leave the furnace for upstairs use.
Old 10-29-2009, 02:01 PM   #6
Thanks guys for the comments & advice!
More On This Topic
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. When framing the basement, we try to find the longest wall possible and square from that wall on. In this basement, this would be that wall. This is a great... Read More »
Newer, more energy efficient homes have been constructed to seal out the outdoor environment almost 100 percent. This condition allows loaded, stale air to accumulate unless windows are opened. Open windows allow some of the heating or air conditioning... Read More »
In a pinch, you can use a ventilation shaft for making an emergency exit from a large building. As long as you aren't given to claustrophobia, and don't end up in the boiler room by mistake, a ventilation shaft makes an excellent escape route. Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Something else you want to think about if you do decide to finish your basement in stages, is access to the plumbing and heating. If you decide to finish... Read More »
How to Do a Rough Duct Test
How to Do a Rough Duct Test by Expert Village
Hi! My name is Joshua Lindsey with CFM Building Science Solution. On behalf of Expert Village, we are going to do a duct test in this house. We are doing a rough duct test on this house. Rough duct meaning literally that the house being built is in the... Read More »
Should I have let the ac guy close off a return? windowman3 HVAC 4 09-13-2009 10:23 AM
Where to put Return air vents in basement sj22 HVAC 12 06-08-2009 11:35 AM
Do I need a HVAC return vent in basement? westing HVAC 12 01-28-2009 02:09 PM
flex duck vs metal duck fhammette HVAC 15 11-09-2008 11:17 AM
Connect metal duct to flex? tigerbalm2424 HVAC 3 03-12-2007 04:30 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
