Old 05-28-2011, 03:23 PM   #1
basement pressure changed by turning on HVAC fan
I have a one-zone HVAC system in my two story house. The furnace and air-conditioning unit are in the basement. When I turn on the fan at the thermostat control, with both the heating and air-conditioning off, I can feel a strong draft under the door at the top of basement stairway. The draft stops when the fan is off. I don't understand the negative pressure in the basement when the fan is running in a closed duct system. Does that mean the duct leak on the return side is much greater, so the basement air is sucked into the duct system?
allbrands is offline   Reply With Quote
Old 05-28-2011, 03:31 PM   #2
You have a leak in your return system.
I had a similar situation and found it using a home made 'tell-tall' consisting of a long dowell with a 1" strip of facial tissue (long side) taped to the end. With that, run the strip over/around, near any seam, joint, panning, filter housing, etc. You will find it.
This should also be happening whenever the blower is running (heating, a/c)>
If you have a gas fired water heater (with vent) in the basement, the negative pressure could cause the exhaust to back draft (CO): Not Good.
V
veesubotee is offline   Reply With Quote
Boiler pressure troubles jduffett HVAC 2 12-12-2010 08:15 AM
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 07:04 AM
Pressure Treated Lumber for Basement? mfleming Building & Construction 5 06-18-2008 09:43 AM
HELP - Lost water pressure to shower after turning off water to house jpw28 Plumbing 8 02-20-2008 09:07 PM
need help turning ugly cellar into slightly less ugly basement space Ann Bouchoux Flooring 2 08-27-2007 05:17 PM
