Basement HVAC Room Question - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-12-2012, 07:03 PM   #16
Rewards Points: 105
Basement HVAC room question
I have had a chance to look at the units. The water heater is 40000 and the furnace is 100000. The furnace is not labeled my but buddy who owns an HVAC company and has worked on it said it is about 100k. He also said I could put a 16x25 return vent on the wall instead of the louvered door. He said it could go at the floor or ceiling.
While I know he is competent with HVAC, I don't know how familiar he is with code. Does this sound acceptable?
The vent would open to the majority of the basement or roughly 700 square feet.
I have attached a picture of the furnace room.
Thanks!
andybeck is offline   Reply With Quote
Old 09-12-2012, 08:01 PM   #17
140K needs 7000 cubic feet of air. Unless you have 10' ceilings 700 square ft isn't enough. Your bud is incorrect and beenthere is correct, needs a high grill and a low grill. You'll also need a high and low in the door connecting the upstairs and basement to pass inspection. You'll be safe with undercutting the door but it doesn't meet code.
Old 09-14-2012, 05:53 AM   #18
imac service's Avatar
If you really want to know have your buddy call the local mechanical inspector she what he says he will accept. Or have your buddy open the mechanical code book and look. I wouldn't do anything until you know what you do will pass code. Sounds like you need to figure out how much combustion airs needed
imac service is offline   Reply With Quote
HVAC return in basement stringers HVAC 0 11-18-2011 03:14 PM
Basement improvement / AFCI Breaker Question BiOs2k Electrical 0 02-25-2011 11:32 AM
question about wiring basement with garage panel 1acman Electrical 4 01-19-2011 12:44 PM
Basement Finish HVAC questions JETJR HVAC 3 06-15-2009 03:06 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
