Old 12-27-2010, 02:56 PM   #1
Basement humidity affect on Humidistat?
Hello all - I have a question on the relation between basement humidity, living space humidity and the system humidistat.
I have an Aprilaire RP-58 humidistat installed on the upper plenum of my cold-air return of my up-flow gas furnace in our unfinished basement. The humdistat is about 12" above the whole house by-pass humidifier (April-aire 600). The humidistat also has an external temp sensor installed. This was all installed per spec and when we had a new furnace installed a year ago, the installtion company checked it out and said all was well.
What I'm noticing is that the living space (1st floor) is indicating about 19% RH on a couple of spot stand-alone hygrometers I set up in two rooms. However, the reading on the humidistat read-out on the basement (RP-58) indicates the RH is 42%.
I have the fan set to run all the time as I also have a UV system installed. So, I guess my question is - how would the humidistat ever call for water if the RH is at 42%? I do have a basement dehumidifier that runs as needed (set for normal). I also understand that a cold outside temperature will affect when humidity is called for.
Do I need to move the humidistat in to a cold air return located in the actual living space?
Any feedback appreciated!
M
mbear2k is offline   Reply With Quote
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 08:36 AM
A few Q's on Finishing My Basement - Is there a FAQ on this? ossrocks Remodeling 6 01-07-2009 01:21 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
