Basement Flooded With The Furnace Taking In Water, What Should I Be Doing For Safety? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-27-2011, 11:10 PM   #1
Basement flooded with the furnace taking in water, what should I be doing for safety?
Basement flooded with the furnace taking in water. What should I be doing for safety concern? I see some wires that are definitely going to get wet.
Bellofjdiy is offline   Reply With Quote
Old 08-27-2011, 11:43 PM   #2
Remodeler
Rewards Points: 330
Shut off the gas and power to the furnace, mostly for safety concern but also damage to the electronics may be minimized if the unit has no power to it.
iamrfixit is offline   Reply With Quote
Old 08-28-2011, 07:46 AM   #3
An old Tradesmen
Rewards Points: 7,776
Get a sump pump. If the water gets to the gas valve, the valve must be replaced.
Old 08-28-2011, 01:59 PM   #4
Replies the furnace. As a contractor I called manufactures to ask for advice on flooded units. If water reaches gas valve it must be replaced.
Hixheat1 is offline   Reply With Quote
Old 08-28-2011, 06:01 PM   #5
An old Tradesmen
Only the gas valves must be replaced, unless the board was under also and can't be dried out.
Old 08-28-2011, 06:53 PM   #6
REP
I'm pretty sure that anything that is live electyricly when it is covered in water is going to short out.
If power is shut off at the breaker panel ,and you can afford to let the unit dry out with maybe some help with a hair dryer,there is a chance nothing will have shorted out.Things like a motor with internal elec windings and such have to be very dry before putting elec back on to them.
REP is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Not another basement water "management" thread! mwpiper Building & Construction 11 02-06-2012 07:31 AM
Basement drain pipe "pit" ground water fix. alecmcmahon General DIY Discussions 13 12-01-2010 05:42 AM
Stumped: Basement water and fix- Did I make things worse? jws3 Building & Construction 27 10-16-2008 07:38 AM
