Basement Finish HVAC Questions - HVAC - DIY Chatroom Home Improvement Forum
Old 06-15-2009, 01:40 PM   #1
Basement Finish HVAC questions
I was hoping someone could give me some advice. I am finishing my basement (2 bedrooms,bathroom,family room, and utility room) and need to work on the HVAC ductwork. Currently each bedroom has a vent, the family room has two vents, and there are no cold air returns.
The building inspector has said each bedroom needs an air return, and the common room needs one as well. The bathroom needs a an air vent as well as a vent outside for the fan (not there) I am not worried about the utility room. All walls are studed and unfinished. I have done all the work up till now myself, plumbing, framing, electrical. How hard would it be to accomplsih this? I was quoted between 500-600$ by a local HVAC guy to do it all for me. It would be adding 3 air returns, 1 air vent, and the hole to the outside for when I add the bathroom fan. Does this seem reasonable? I am not confident in doing it myself, but would learn if I could.
Any advice?
JETJR is offline   Reply With Quote
Old 06-15-2009, 01:58 PM   #2
Seems like an excellent price. If you trust the contractor, go for it .
SKIP4661 is offline   Reply With Quote
Old 06-15-2009, 02:06 PM   #3
He did some
Old 06-15-2009, 02:06 PM   #4
He did some air conditioner work for me when I accidentally drilled through my freon line, and did good work. I was leaning towards having it done, will be a lot easier I think.
Do I need a HVAC return vent in basement? westing HVAC 13 04-03-2014 01:43 AM
Basement floods and have some questions andyroo89 Plumbing 7 04-01-2009 05:50 PM
Paint recommendations and finish questions EJacobs Painting 2 09-03-2008 10:38 PM
Considering Cork for Basement ... LOTS of questions! :) njchan Flooring 5 01-26-2008 08:05 PM
