Basement Cooling Advice - HVAC - DIY Chatroom Home Improvement Forum
Old 04-08-2009, 12:18 PM   #1
fdb
Question
Basement Cooling advice
I need to cool/heat/dhumidify a 500 sq ft room in the basement.
This is an interior room so there are no windows. My Central system is in the attic so it's two levels up, therfore no ductwork exist in the basement.
I have considered a portable unit and cutting a small hole in the siding to vent it. I have also read about the mini split systems but they seem pretty expensive. Currently the entire basement is being dehumidified by
two of the units that you roll around and have to emty the buckets on.
The unfinished area is probably around 1000 sq ft.
Any suggestions?
thanks
Frank
fdb is offline   Reply With Quote
Old 04-08-2009, 12:23 PM   #2
Rewards Points: 1,274
Any suggestions?
thanks
Frank
For cooling & dehumidifying how about one of those rollaround windowless air conditioners that exhaust / intake through flexible hoses? You could run them out through the unfinished space to a window. I don't know if those units have a heat option.
LawnGuyLandSparky is offline   Reply With Quote
Old 04-08-2009, 12:30 PM   #3
fdb
i looked at those but the hose is only 59" and i would need more.
Old 04-09-2009, 05:06 AM   #4
sweaty
Rewards Points: 276
Before going to all this trouble and expense, seal and insulate your house. Especially your attic and basement. It keeps out heat, cold, and moisture. Doing your attic helps your basement because it reduces the stack effect, where warmer air rises and goes out the top off of your house, sucking in cooler outside air into the bottom of your house.
sweaty is offline   Reply With Quote
Old 04-10-2009, 02:25 PM   #5
fdb
portable unit
Any idea which portable units are better?
Which models have the dual hose system?
I read thet were more efficient but haven't
seen a specific model.
thanks
Frank
Advice needed for filling large basement Cracks dgbehrends Building & Construction 11 11-17-2009 04:23 AM
Basement floor advice gbwillner Building & Construction 13 03-17-2009 12:04 AM
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 01:29 PM
Advice for choice of basement flooring dgates Flooring 8 09-28-2008 11:47 PM
New poster, looking for advise on heating cooling in basement that is being finished blthomas HVAC 11 12-07-2007 10:07 AM
