Basement Cold Air Return - HVAC - DIY Chatroom Home Improvement Forum
Old 03-23-2008, 12:10 PM   #1
Basement Cold air return
I am finishing a basement room which has 4 concrete walls. I would like to put the cold air return near the floor. What are my options to move the air past the framing header? Cold air return for the upstairs bedrooms run through the ceiling above the room in question, i would like to tie into these returns.
Could I just remove the header in the two cavities that will have the cold air return, if so how would this affect fire blocking?
Thanks,
Ben
Bcoleman6 is offline   Reply With Quote
Old 06-05-2008, 09:49 PM   #2
i am curious as well
ro9beam2002 is offline   Reply With Quote
Old 06-07-2008, 09:42 AM   #3
Where is the HVAC unit ? In the basement or the first floor ? The headers can be removed as long as its a bearing wall. If its a bearing wall then you may need to add some more supports. As far as fire blocking, if a fire breaks out upstairs, your downstairs is pretty much toast anyways.
muddog is offline   Reply With Quote
Do I need a HVAC return vent in basement? westing HVAC 13 04-03-2014 02:43 AM
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 02:29 PM
Basement Return Location handy man88 HVAC 2 10-31-2007 07:53 PM
Running network wiring in a cold air return vent? mcvane Electrical 26 04-19-2007 08:52 AM
